window tinting on rear hatch ??
Old Dec 11, 2006 | 10:49 AM
Bill Hetzel's Avatar
Bill Hetzel
My 92 was done with a seam in the middle,can't see it. It was done about 7 years ago.
One corner is starting to lift up a bit. Has anyone tried to fix something like this? It's not bad enough to take to a tint shop.
Old Dec 11, 2006 | 01:32 PM
Mekanic's Avatar
Mekanic
Originally Posted by chillcat
Mekanic--I know exactly where they are now, thanks...I'll be driving on ridge to get to 19--so I'll just stop by.
let me know when youll be in the area, I'll head up there and you can see mine
Old Dec 11, 2006 | 01:45 PM
Hotred94's Avatar
Hotred94
A good quality tinter will remove the struts and cut around them; the struts twist back and forth, and the cutout prevents that twisting from wrinkling the tint around the holes. They will also do one piece and fit it with a heat gun to mold it to the curves. Then they will trim the door windows down about 1/8 inch from the top inside edge and sand the edge of the tint down so it won't get peeled off by the window going up and down. Make sure the tinter uses only top quality metal vapor tints with a lifetime guarentee. Cost for this kind of job will be $170-$200.
Old Dec 11, 2006 | 04:31 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Originally Posted by Mekanic
Aha! cool, I just had mine done at an AWESOME place, did the back in 1 peice, and looks fantastic!
Are you in Crystal River? If you don't mind drving a little bit, the place is in Port Richey, its called National Window Film Distriutors Inc.
On a C4 they like to do them on Saturday, because instead of cutting around the hatch struts and latches, they remove them and do it all the way.
their # is 727-849-4874
Tell them Rich with the green 96 sent you
How much did they charge you??
Old Dec 11, 2006 | 05:22 PM
TIMSPEED's Avatar
TIMSPEED
Once again I was the only bastige with a C4 there.
Correction... not "a" C4...THE C4.
Old Dec 11, 2006 | 07:16 PM
Mekanic's Avatar
Mekanic
I believe normal price for a C4 is $170, thats front and rear, 20% in back, 15% in front, which is florida legal, with a lifetime warranty.
Old Dec 11, 2006 | 10:08 PM
chillcat's Avatar
chillcat
Mekanic, I'll be there Saturday at 9am, they are doing my hatch and both doors for $140 cash...Sounded like a good deal, they said they install tint on corvettes quite often....The guy said he installed a silver film on yours but couldn't do the same to me, due to the fact that you already had silver film and was just getting new stuff on, he said they don't install silver film unless a situation like yours....
Old Dec 11, 2006 | 10:27 PM
Raidmagic's Avatar
Raidmagic
I had a guy here in Brandon do mine. Removed the old tint and retinted with a one piece rear window for $150.
Old Dec 11, 2006 | 10:39 PM
Mekanic's Avatar
Mekanic
mine isn't silver lol, Mine is 15% in front and 20% in back, FL legal black tint heh.
screw it tho, I'm supposed to stop be there anyway so they can check up on the tint, so I'll make the trip saturday morning
Old Dec 11, 2006 | 10:47 PM
chillcat's Avatar
chillcat
cool, I'll see ya there anyhow!! He must have mistaken your car with someone else's, yeah, I'm getting the darker stuff in back and that medium color in fronts...Must be the same you have, see you there
Old Dec 18, 2006 | 01:50 PM
Mekanic's Avatar
Mekanic
Sorry I didn't make it up there, I had a long Friday heh.
How did it turn out?!
