C4 engine ?
If you are going to all the trouble to change the engine, why not change the fuel injection as well, and get some more kick to that gas pedal?
I have a complete fuel injection set-up for an 86 that gives you computer, harness, all sensors, later exhaust, and all the goodies to make it run way better.
includes cam, distributor, throttle body, injectors, ignition module, etc.
it even includes the firewall harness feed through and the lights, alternator, smog, etc. is already in the harness
asking $1000 for everything
one plug deserves another one
If you are thinking about freshening up the van motor, have a machine shop do a good 3-angle valve job on the heads and knurl the valve guides. Check the crank and all of the crank and rod bearings for any indications of wear. I would also install a new oil pump.
Use all of the brackets and accessories from the L83. It would be a good time to get a new water pump, thermostat, distributor cap and rotor, plugs, wires, hoses, and belts. Check the belt tensoner and idler pulleys and replace as needed.
If your 84 is a manual tranny car, you will need to add an input shaft bushing in the rear of the crank.
Don't, I repeat, DO NOT spend a nickel, let alone a thousand dollars to swap over to a TPI system. It is a lot of money and a lot of work, all for no gain in performance. The manifold fitment situation is the same with the TPI manifold as it is with the Crossfire, so it doesn't even save you that hassle.
The 1984 Crossfire cam is pretty mild. The '84 ECM would have no problem dealing with the '91 engine as is. You might take the opportunity to up grade, if you like.
As mentioned, you will need a 1986 and up flywheel or flex plate, whichever your car uses. Make sure the damper on the front of the engine is no larger than 7" in diameter to clear the front cross member. Use all the 1984 accessories and sensors in the same locations they were in on the '84, and it should be a simple bolt in.
RACE ON!!!
I second what was said above about swapping to TPI; not worth the money.
The '84 ECM will deal w/the truck long block fine. It's even MORE conservative than your original long block. Read on...
Your donor engine is the swirl port, TBI 350 with what is refered to as a "peanut cam". Less than 200* on both sides and less than .4" lift also. SUPER lame cam. The heads in stock form are worthless for developing any kind of power, as half the intake port is blocked off by the intake valve guide (as cast) to promote swirl. That engine w/stock CFI, headers and optimized timing and fueling is good for about 230 hp at the crank at MOST. In other words, swapping in that long block, you'll lose power due to a smaller cam and worse heads. It will run and function fine though.
In my T/A, I got a 14.6 @ 95 out of that same combo (and headers) w/a 5 speed and 3:42 gear, in a 3200# car. That's about 220-230hp. i'd look for another long block, OR reuse your heads and slap in a $90 Summit cam.
RACE ON!!!
What I'm getting at, is why not just rebuild the old engine? Is this an issue of cost and the van engine is free? An issue of time where you want as little downtime as possible? Combination of the two?
You could just pull the engine and have a machine shop give you an estimate on rebuilding it. It's a small block Chevy...nothing mysterious about it. And a basic rebuild shouldn't be terribly expensive. Or if you don't want the downtime, a basic LM1 crate engine will get you back on the road.
As everyone above mentioned the van engine will work....but I have doubts as to how satisfied you're going to be with the result.
You can always put the van engine in, and mothball your original engine in the shed somewhere. Down the road when you find the $1200 in your sock drawer, you can rebuild it then and swap it back in.
Good luck with the project.
