Rolf Persson
Old Dec 11, 2006 | 09:27 AM
Rolf Persson's Avatar
Rolf Persson
Default Rolf Persson
is there any one that can tell me what UART failure means it comes up on the system diagnostic codes on the HVAC i have a 90 with c68 system
Old Dec 11, 2006 | 10:25 AM
bogus's Avatar
bogus
UARTs are a type of communications chip/microprocessor. Once one fails, it needs to be replaced.
Old Dec 11, 2006 | 10:31 AM
Tom Piper's Avatar
Tom Piper
My guess is there are uarts in the C68 control unit and the Programmer under the dash.
There is a dedicated serial link between these two units.
Probably, something has failed for this link.
Tom Piper
Old Dec 19, 2006 | 08:53 AM
Rolf Persson
Default Heater and a/c programer
thanks for the inf maby someone can tell me if that could have any thing to do whit a battry drain i am trying to find it is true the curtesy fuse and i have disconet everything i can thing of and it stops when i disconecting programer have disconetet radiocomponents, light, ecm,ccm a/c controller i dont now if there is somthing i need to check before i change the programer somthings i need to thing about and if there is any good repiaer shop thath i can send the electronic componetes for checks and repears
Old Dec 22, 2006 | 06:39 AM
Rolf Persson
Tom Piper
Thanks for the info mabye someone can tell me if that could have any thing to do with the battery drain i am trying to find.... it is through the courtesy light\fuse and i have disconnected everything i can think of ....and it stops when i disconnect AC and heater programer, have disconnected radiocomponents, light, ecm,ccm a/c controller. I don't know if there is something i need to check before i change the programmer ....something i need to thing about and if there is any good repair shop that i can send the electronic components for checks and repairs. I am located in Sweden. Appreciate your help and reply.
Old Dec 22, 2006 | 09:20 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
All i can offer is some info on the C68 climate control.
http://members.shaw.ca/dankai/AC%20Electronic.pdf
Old Dec 22, 2006 | 02:17 PM
tonymax2's Avatar
tonymax2
Right on! UART, Universal Asyncronous Receiver Transmitter. If it's marked with the generic part number, you could probably get one for pennies and replace the one (which one?) that's bad. Problem is, that kind of info is almost impossible to get and GM's supplier never intended it to be repaired. I'm suprised it even told you that level of detail. Essentially what it means is you have the choice of replacing the whole unit or doing without but you can feel comforted in the fact that you know why! You might want to search for the posts concerning reversion of the C68 auto control to C60 manual control! When I finally get "my" '89, I'll likely have a complete C68 system for sale 'cause it's one of the things on my "hit" list. Good luck!
To Rolf Persson
