I searched but I didn't find anything on this topic so here goes - would it be foolish to put a LT1 intake on a 383? I'm planning out a future build and while I don't want to be cheap in the wrong places. If a LT1 intake isn't a gross hindrance on a 383 It seems it would be the least expensive option for an intake. I'm realizing that the L98 heads and intake aren't going to cut it on a 383 so I guess they will go onto my '93 K1500 pickup
The LT1 intake is dry, so there are no coolant cross-over passages which you'll need.
The LT1 intake doesn't have a hole for the distributor, so you'll need to drill one.
As I recall, the holes for the intake manifold on an LT1 intake won't line up with Gen 1 SBC heads unless you modify them (again, I'm not 100% certain on this but I recall hearing that during a conversation with a GM powertrain engineer years ago).
Thanks 96GS#007 I'm aware of the modifications require to make the intake work. I'm more concerned with the kind of air the intake can flow. Building a 383 then bottlenecking it with an inadequate intake would not make much sense. Thus the reason the L98 intake has to go.
