Car is an 96 LT4, friend of mine. He has asked me if I know what would cause the steering to become very stiff and then become normal again. Usually happens just after start-up, barely moving, and the first turn of the steering wheel. Happens when he backs out of the garage, onto the street and then when he goes to turn the wheel to go down the roard, its really stiff. Happends again in the parking lot after work....eiher backs out or pulls forward and then when he goes to turn...very stiff wheel. Afterwards, everything is fine.
Has check fluid level--okay...no leaks, belt good.
try a bottle of lucas ps fluid. use a baster to drain fluid out of reservoir. for6 or 7 bucks, worth a try. i did this on wifes 88 3or 4 yrs ago, and still working fine.
From: One day you're a Comet...the next day you're dust... Arkansas
Draw some PS fluid. If it is dark replace it. I just did mine. Use a plastic turkey baster. To replace most of it draw 2 cups at a time, replace with new fluid, drive it, repeat. It took almost 2 quarts (4 repeats) to get most of it. I used Valvoline for older cars 75,000+ fluid. This cured it.
I had a very slight PS leak. After adding about a quart of Valvoline Syntec, the leak stopped. No drips on garage floor for about 8 months. I read this is not a fully synthetic product, but many forum members recommended it and I like the results. Also used their brake fluid with no problems.
I will relay this information to my friend...and also change out the PS fluid in my 96....
Do I need to worry about bleeding air out? By lifting the front tires off the ground and then with engine on turn the wheels lock to lock couple of times?
Mine has morning sickness every winter. Just turn the wheel a few times before you take off. The Lucas really does help.
