running rough
Old Dec 12, 2006 | 01:25 PM
franks96ce's Avatar
franks96ce
Default running rough
i came to start my car this morning and it started kinda rough and smoke came out frome the mufflers.which is not usual, and there was a wied smell so I turned it off and restared it and it stared the same way.the smoke only came out when I started the car and reved it a little.the car has 109,000 mk.
Old Dec 12, 2006 | 01:28 PM
mikey whipreck's Avatar
mikey whipreck
Color of smoke? Noticeable leaks?
Check your coolant (in your radiator and overflow tank)
Check your oil (color and level)
Old Dec 12, 2006 | 01:30 PM
RRT vette's Avatar
RRT vette
Smell of smoke?
Leaky injectors?
Coolant in the exhaust?
franks96ce's Avatar
franks96ce
smoke was like a clear white
Old Dec 12, 2006 | 01:31 PM
B!@cK 86 V3tt3's Avatar
B!@cK 86 V3tt3
Smoke is from coolant/oil in the exaust. ALSO...it could just be condensation on startup because of cold nights ect. This would only be light whisps of smoke. Dont know how much you have though.
Old Dec 12, 2006 | 01:38 PM
franks96ce's Avatar
franks96ce
oil is good any sugg on that rough start,the car was sitting for like a week sense i last drove it.its been startin good untill now.
Old Dec 12, 2006 | 02:38 PM
RRT vette's Avatar
RRT vette
You mention smoke coming from the exhaust that is unusual. Since it's getting cold now this could just be condensation burning off. If the smoke is white and a good bit it is more than likely coolant in the exhaust probably caused by a bad head gasket, ect. Blue smoke is an indication of oil getting past the rings and burning. A rich gas smell of exhaust is an indication of leaky injectors which can cause it to run rough. If it's been raining a lot there lately and it sits outside. You might have water in you fuel. Check to see if water is sitting on the rubber filler neck caused by a stopped up drain.
To running rough
