You need some way of timing the spark. You can’t get rid of the opti entirely. But you can eliminate the cap or high voltage section of it. You still need the resolution pulses to trigger some kind of ignition system. I believe Delteq makes a system that uses coil packs plus their own ignition system. The rear section (or low voltage) of the opti is used to trigger the system. The system does use some real estate under the hood.
The 95 and 96s have the vented opti which is better than the old. The optis really work well with very precise spark timing. It is just in a rough spot but that is one of the factors, using direct drive that gives it its precision.
Its really a great system more accurate than anything else around.
I guess I am one of the few who like the opti. Its hidden, and seems to work very good. I have replaced the water pump, and it seems not that difficult to service.
It's mostly maligned because most people don't understand it. All it is basically, is a crank (cam) sensor with a ridiculusly expensive (GM proprietary) distributer cap and rotor. With the exception of getting wet, they're VERY relilable. I've had ALOT more problems with bad coils and bad ignition modules (technically part of the opti-spark system) on LT-1's. It's kind'a like the VATS, it gets blamed for everything. There's not a week that goes by that there are SEVERAL posts saying they "wouldn't buy an LT-1 because it has an opt-spark".
I do basically agree. I have done it a few times and it does now seem easier. Its a mind set! However the first time the walls seemed much higher. My biggest problem was getting the balancer off the first time, it was really on there. After that, it falls off now since lubricated.
Hey Tracy, do you remember seeing the Delteq setup on my car at Phils house? Like the others have stated you still need the opti for the trigger. I sealed mine with RTV when I put it in. I like the fact that the spark plug wires are ALOT easier to get to, plus it eliminates the ozone in the opti which I've heard leads to corrosion and bearing failure. Piece of cake to install. Robert
local 4x4 kamikazes drill the back of the lt1 intake and use an HEI distrib with early tPi ecm, just leave the opti to cover the hole...they say the opti is no good when driving thru streams that are 4 ft deep
Robert, I do remember now that you mention it. However I'm wondering how effective it will be with all the work I have done and when the blower gets put on. I'm not one to only do half the job. I know I have seen guys use the coil packs and a crank trigger for precise timing. I was hoping to find someone that has already done it.
It is best at this time to take a moral high road. He may be at fault, and judging from the comments, he might be. But publically airing the dirty laundry does nothing but hurt your reputation. Sad, isn't it?
With that said, I cannot understand how the Dynaspark could be causing a knock. Unless there is something wrong with the high voltage, and that would have other manifestations. On top of that, if it was the optical side, I am sure codes would show up.
You may be right. It is difficult to sit back and allow things like that to be said when it may affect business. I've decided to edit posts for PLRX's sake, hopefully he comes around.
The only way the opti-spark could possibly cause predetonation is if the timing were off. I will say that there is only one way to assemble our distributor and it ends up being dead on with stock timing. If anything were wrong with the Dynaspark it would be a simple fix on our part and we would be willing to take care of it free of charge.
Sorry to Hijack the thread, back to the topic at hand...
Like most people have said, getting rid of the optispark is impossible. You can eliminate the cap and rotor with the delteq system however the optical sensor still poses a threat to reliablitiy. We are not a supporting vendor (yet) so thats all I'll say for now.
I don't know what provoked this comment, but I can attest to the value of the DynaSpark unit. I've had one in my '94 for over two years now, and it has performed flawlessly.
I hold the DynaSpark in very high regard. I've done quite a bit of mechanical design work and I am not easily impressed, but the Dyna impressed me as soon as I opened the package and inspected it carefully. It is a quality piece.
I would recommend the Dyna to anyone who is looking for a replacement for the Gen1 Opti.
I read the comments. Yes, they responded to me weeks after my first inquiry and they tried to diagnose my car thru e-mails. I'm very, very happy for those which the dynaspark works and I envy you. The optic spark in my 92 had 195,000 miles and it worked flawlessly until the Vette's very last day. Maybe like some other VETTE owners with the optic sparks, my dynaspark is giving me some problems. Unfortunately for me, my job does not allow me to just go home M-F and "take it out" in 15 minutes so I can send it back. To remove it, takes patience, time and money.
Like I said before, it is your money, you earned it and you may expend it at your convenience. I respect everybody opinions (airfoils, oil magnets, etc.) My opinion?, Save money by buying a new Optic Spark from the dealer. Try EBay....
getting rid of the optic is NOT impossible... The most common cause optic failure are the cap and rotor. The optic crank signal reference are rarely the cause of optic failure.
There are 4 options to long life the ignition.
1) Use a Delteq system (multi-coil pack) No need for MSD box ever
2) Use LTCC system (multi-coils pack) No need for MSD box ever
3) Convert to HEI ( this will totally got rid of the optic
4) Convert to crank trigger and use multi-coil pack.
If I have not bought the delteq system. I would have go with crank trigger. My friend 1995 turbocharged 383ci that he is using crank trigger, it look really good and cool stuff.
I am happy with my delteq so I will leave it at that..
