More Exhaust stuff- Cats
Old Dec 13, 2006 | 12:04 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default More Exhaust stuff- Cats
My engine is nearing completion and we will get around to the install in a few weeks. I am going back with headers (Had them Jet hot coated). From the Headers back is a decision I have to make. I currently have an older 3" B&B Triflow exhaust sitting at the shop. I have no catalytic converters. This exhaust is really to loud and all the typical resonance at highway cruising speed in 6th gear. The car is to loud to speak to another person in the cabin at highway sppeds. Time to quiet this monster down. Yes, I am married.
Questions.
1.) If I add Cats to this set up will it cut my resonance? I would think that it would lower the decibels blowing through my exhaust but I am not sure about resonance. The resonance is literally ear stinging.
2.) A local exhaust shop has told me they can custom build a system that would include cats and dynaflow mufflers for around $700. How are the dynaflows.
Car is modded as follows: 94 coupe, 6 speed, LT4 hotcam, crane roller rockers, Hooker long tube headers, SLP intake with three K&N filters..
Opinions and solid advice on your set ups. Yes, I ask some of these questions in the past, however, that was months and months back. It is now time to spend money. So I need input.
Old Dec 13, 2006 | 12:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
With your mods I would expect you are developing over 350chp. This means you need 800cfm of exhaust flow, or 400cfm per side.
Check out the intended cats & mufflers for flow specs to assure they won't cost any HP.
BTW, I know a guy who has Corsas on his GS and loves the sound. They sound deep at idle and he says they are quiet enough while cruzin' but roar at WOT.
Old Dec 13, 2006 | 12:20 PM
TM-Z06's Avatar
TM-Z06
Cats will lower the decibel level, but they will NOT cut the resonance. IMHO, there is only one cure for the resonance - Corsa.
If it were me, I'd add some gears - 4.10's. They keep your rpms up and out of the "drone-zone" so the resonance is not as bothersome.
Old Dec 13, 2006 | 12:24 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default 350+ I hope so
I hope 350 plus. Alot of work to the engine - balanced rotating assembly, ported and polished the headers... The engine is going to be a real screamer, I don't want everyone to hear is coming for a 20 mile radius.
I like stealth
Old Dec 13, 2006 | 12:33 PM
vader86's Avatar
vader86
Cats would reduce the noise level, and possibly change the resonant RPM a bit, but kill it? no they wont kill it.
There are several things to do to cut the resonance, but there is no way to eliminate it without going to something like Corsa. Crossover pipes, a resonator, extending the tips past the bumper more, or just plugging up a pipe with steel wool have been tried and help reduce it.
Old Dec 13, 2006 | 12:55 PM
Z06_BluByU's Avatar
Z06_BluByU
I don't know if I agree...
My stock exhaust didn't resonate..
My stock exhaust without the converters on it resonates in OD with the converter locked up below +/- 55-60mph.
Old Dec 13, 2006 | 01:05 PM
Carpenter's Avatar
Carpenter
Jakers,
My vette came with cheap turbo mufflers when I first got it.....the resonance was awful. Couldn't talk at 1600-2000rpm. I know exactly what you're talking about. If I wanted my wife to continue riding with me I knew I had to change it! (Actually, the REAL reason is I didn't want to blow my speakers )
I put on Dynamax mufflers and the resonance dropped by at least 90% (100% being none at all). I like these mufflers, as they sound like equals to the renouned Corsa system. (rumble at idle/throaty at mid and no resonance/wild at wot)
My exhaust set-up is: Stock manifolds, two cats, no crossover, true dual. I have a cam and at idle you hear it well.
Old Dec 14, 2006 | 09:51 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Hushing a B&B
Anyone had any success reducing or eliminating the resonance in a older B&B system?
Old Dec 14, 2006 | 10:55 AM
fc_soldier's Avatar
fc_soldier
I have a borla with xpipe and mines pretty bad too. I was thinking that the x-pipe would help the issue it didnt but good performance gain.
Old Dec 14, 2006 | 05:45 PM
Carpenter's Avatar
Carpenter
Hmmmm FC,
I was considering the hp gain in adding an X pipe myself. I've wondered if it would increase the resonance of my system? Thinking it wouldn't....because of the mufflers I use (Dynamax)???
Your thoughts?
Old Dec 15, 2006 | 03:13 PM
Perfusion's Avatar
Perfusion
Originally Posted by Carpenter
Hmmmm FC,
Your thoughts?
Once upon a time, TM-96CE and I had nearly identical exhaust setups (Corsa), only he removed the center resonator section and replaced it with an X-pipe. Needless to say, the 2 cars sounded COMPLETELY different at idle, mid-RPM, and WOT (we were at a local dyno day), with his being *much* - and I mean MUCH - louder than mine! I was extremely surprised at the difference in sound, and I wouldn't have believed we had (nearly) the same setup if I hadn't seen the underside of his car with my own eyes - it was that drastic of a difference.
I'm sure he'll agree if he sees this post!
Old Dec 15, 2006 | 04:35 PM
BerniesVette's Avatar
BerniesVette
I removed the stock convertors on my '92 today; the rest of the system is stock. It sounds much better now with a noticable increase in torque. There was no resonance increase; just a better sounding system.
Bernie
Old Dec 15, 2006 | 05:01 PM
STL94LT1's Avatar
STL94LT1
I would have to see track times or dyno sheets to believe that claim.
Old Dec 15, 2006 | 05:47 PM
BerniesVette
It doesn't take a dyno sheet for me to be able to feel the difference after removing the convertors. They were the original ones and removed them because I felt they were clogging after all these years. The car responds better than it did and the exhaust note is now a nice rumble instead of a whisper! Your "BS" is my reality!
Bernie
Old Dec 15, 2006 | 09:08 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Quick question, where do you all go to have your cats removed and a straight pipe installed in their place? Will an exhaust shop do this in spite of the legal issues of going catless?
Also how much does this cost? I need to have this done right away because my passenger side cat is completely stopped up, and rather than put new ones on I was going to just drop the extra weight.
Old Dec 16, 2006 | 11:31 AM
BerniesVette
It is my understanding that if you cut the cats off and drive the car to a muffler shop they will install the pipes for you but they will not remove the cats and do it. I have friends that race and have the equipment to do this. I paid them $75.00 for their effort.
Bernie
To More Exhaust stuff- Cats
