Front Liscense Plate Install
Old Dec 13, 2006 | 05:25 PM
mrthex's Avatar
mrthex
Cruising
Default Front Liscense Plate Install
Oregon doesn't allow 1 liscense plate in the rear so we have to install the front too. I see no where in the owners manual how to remove the front corvette insignia blank, any help would be appreciated, I have ordered a manual but it hasn't arrived and i want to be on the road, legally.
Thanks Ron
Old Dec 13, 2006 | 05:27 PM
VenkmanP's Avatar
VenkmanP
Just remove the screws and then remove the filler.
Old Dec 13, 2006 | 05:29 PM
mk842766's Avatar
mk842766
Thanks Ron
Ron,
A couple of screws are up under the bottom lip..take those out, and then there a two tabs in the top, that fit into a couple of slots. Once you take out the screws, pull the plate out, and down, and it should come off...
Cheers,
Michael
Old Dec 13, 2006 | 06:52 PM
serge's Avatar
serge
From: Olympia Washington 91 Z07 Coupe, 6spd, Borla Exhaust, Perf. Ignition, K&N Filter
if its a 91-96 i will buy that lisence plate cover if you dont want it, pm or email me if you want to sell it.
Old Dec 13, 2006 | 09:06 PM
mrthex's Avatar
mrthex
Cruising
Default Liscense plate fixed
Thanks gentlemen for the come back, and serge it is an 85 sorry.
Old Dec 14, 2006 | 11:25 AM
ZR-1MIKKO's Avatar
ZR-1MIKKO
I need a front plate cover for '85. Let me know if you would like to sell your cover?
Old Dec 14, 2006 | 02:01 PM
hardlight's Avatar
hardlight
After you put a plate in the front, several sources sell a clear plastic cover that installs just like the painted piece you removed.
To Front Liscense Plate Install
