Don't forget the PBR-type sliding calipers use BOTH ends of the piston bore to apply grip. Thus the effective piston area - in terms of hydraulic pressure - is double the face area calculated above. HTH
Kaiser:
That is interesting. Please explain, I was not aware that the effective area was doubled; but I am by no means an expert on the PRB sliding caliper.
There's nothing to be an expert about. Look at the caliper - each pad is reacting one end of the piston bores, and is constrained by the rotor surface. Thus the clamping force is fluid pressure times double the two pistons' face area. To say it another way, both ends of the piston bores are free to move, so they become double-ended hydraulic cylinders. The total force is the same as if it were a 4-piston fixed caliper.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thank you for this very important point. I'm so used to dealing with fixed (four piston) calipers that I didn't think this through completely. Very useful point.
Originally Posted by bill mcdonald
What are you brake plans?
Sounds interesting.
I'm working on a hybrid suspension combination. I'm putting a C4 F&R suspension on my spare C3 frame, but continuing to use the stock 15" aluminum wheels (I like the looks of my '69, just not the suspension geometry). I have a set of Wilwood four piston fixed calipers on the back, and am trying to find a rotor/caliper combo in the front that will work well, and still fit under the 15" wheels. The rear was fairly easy, although labor intensive, but the fronts are giving me headaches. There's just not as much room in the front wheel area due to the steering arm (tie rod area) placement. I've got most everything in this conversion either welded in, or calculated for fit. The front brakes are the only holdup at the moment.
