calling Pete K
Here's the scoop - Tranny was rebuilt but never worked 100%. At first, there was a kick down issue - it wouldn't kick down at all. Brought it back to the tranny shop and they told me it was the cable. They put a new one in and it did the same thing. Brought it back again and they did something that made it kick down from OD to 2nd, but still wouldn't kick down from 2 to 1. THEN, it developed this shake in OD at low RPM. I thought maybe it was the 4 prong clip for the lock up because it was damaged when I pulled the engine & tranny. I replaced the connector and it got worse - now vibrates in 3rd and OD.
I unplugged the connector to trouble shoot, and the tranny works fine - kicks down like it should, no vibration.
The vaccuum is all out of whack on the car. I eliminated all of the pollution crap. The car runs excellent. Is there some sort of vaccuum switch or selonoid on my 87 that could be causing this. If so, why did it come on gradually? I would think if it was vaccuum, it would have done it from the get go. Also, is there some selonoid by the battery that I can change? Can anyone tell me how to identify it? I am trying to do everything I can before I open the tranny.
There is more to lock up than the solenoid. The other parts are
Wiring harness
Pressure switch(s)
Temp switch(later years)
ecm signal
torque converter
lock up valve assembly.
As far as the poor shift quality, that almost always points to tv system. I would strongly advise pressure testing the trans to assure correct tv pressures. Typically they are approx 50 psi on the low side and 150 psi on the high side. Consult the manual for your exact year and model trans. The code is stamped in the pan rail flange on the pass side.
