Minor explosion? OOPS!
Old Dec 18, 2006 | 06:11 PM
scorp508's Avatar
scorp508
Originally Posted by LPDesRoche
Because if I had the 60's in there right now they would have to be running so low a pressure and small pulse width that it would probably effect driveability to a point.
You mean fuel isn't supposed to drizzle into the cylinder as opposed to mist?
Glad it sort of worked out for the best, Lee. Can't wait to see whaty ou do with it.
Old Dec 19, 2006 | 07:32 AM
LPDesRoche's Avatar
LPDesRoche
That's how the whole explosion started in the first place. Damn drizzling fuel.
Lee
Old Dec 19, 2006 | 10:03 AM
BigLee's Avatar
BigLee
it could also be a faulty fuel pressure regulator, instead of the injectors.
if the diaphram inside the regulator splits, it will send fuel into the manifold through the vacuum line. make certain its not your regulator befor buying new injectors...
and if the oil is fuel contaminated, change it.... dont put your engine at risk by driving it like that. i have a friend who can vouch for the carnage that driving with fuel contaminated oil can cause....
