Agent, I can't believe I haven't asked you about this yet.
How does the AIR delete affect us BC guys?
Have you done any header/cat/precat stuff as well?
Any aircare related info is gold man...
I have non emission long tubes, no cats and no air pump. There is no air care in the Okanagan.
It's been 12 years since i lived in the lower mainland, but all i recall was them stuffing a sniffer in the pipe and taking some readings. If that is still the case, a good running motor will pass that test without the stock headers and cats.
If your talking about the air pump delete bracket, here is the info. http://members.shaw.ca/dankai/Air%20...Delete%20Info/
It's seems some printers distort the template somewhat, so making a plastic or plywood template to verify fit, would be a good idea.
