pink injector question
Old Dec 16, 2006 | 11:34 AM
gator79's Avatar
gator79
Default pink injector question
I have aquired a set of (free) ford pink top injectors, out of a low mileage 2003 mustang GT. does anyone know the flow rate of theese? would they work in my '93. I have a injector on mine that gets loud at times.
Old Dec 16, 2006 | 03:45 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I have them in my 86. They are a great match for the L98, very, very close to stock numbers. I can't comment on the LT1's.
Old Dec 16, 2006 | 05:23 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
I have a set in my 92, they flow close to the stock injectors as Ford rates them the lower due to the lower pressure they run. The stock pressure( GM) brings the rating to about the same as the stock injectors
Now one thing you must do is make sure to use the top groove to clip it on the fuel rail as the Ford injectors as they are alittle shorter than the GM injector. If you do not you will have vacume leak at the bottom bung as the o ring wont seal the bung.
Old Dec 16, 2006 | 05:30 PM
lefoy84's Avatar
lefoy84
That's why I don't like them. Sent mine back plus the pink is not to my liking.
Old Dec 16, 2006 | 10:02 PM
gator79's Avatar
gator79
I might just have to try it for free
Old Dec 17, 2006 | 06:59 AM
RRT vette's Avatar
RRT vette
What size lb/hr are they? Your injectors, if stock, are 22 lb/hr.
To pink injector question
