Idle Problem
Old Dec 16, 2006 | 01:30 PM
Doug 87L98's Avatar
Doug 87L98
Default Idle Problem
My son has a 89 Z28 with a L98 engine.
Just yesterday his car developed an idle problem while driving. When the car is idling it starts to die and the RPMs drop to under 100, and then it surges back to normal idle RPMs and repeats in a very rythmic fashion. While under power the car seems fine. Also at start up the car seems fine. This seems to only happen while idling.
I know this is a Corvette site, but I've never encountered this problem on my 87 Vette, so I was hoping some one could point me in the right direction in diagnosing this problem. It is a Vette engine ..... right?
Thanks.
Old Dec 16, 2006 | 01:45 PM
_twisted_'s Avatar
_twisted_
check the throttle body shaft for excessive play - it could also be a lazy IAC valve
Old Dec 16, 2006 | 10:15 PM
Sam Lam's Avatar
Sam Lam
Any codes displayed when you short A&B on the ALDL? It sounds like an IAC motor problem as the car runs well under load.
Old Dec 17, 2006 | 06:57 AM
RRT vette's Avatar
RRT vette
Sounds like a vacuum leak or a dirty/lazy IAC. The IAC is located in the bottom of the throttle body. I would be leaning more toward a vacuum leak.
Old Dec 17, 2006 | 09:07 AM
Doug 87L98's Avatar
Doug 87L98
Thanks guys.
My son is at work now. We will check it out when he gets home.
Old Dec 17, 2006 | 09:39 AM
nyernga's Avatar
nyernga
Mine did this back in August right before a long road trip. No codes but it turned out to be the O2 sensor.
Old Dec 18, 2006 | 11:50 AM
Doug 87L98's Avatar
Doug 87L98
Thru a minor miss-hap, my sons car ended up at the dealer. So while it was there I had them pull any codes. The O2 sensor was the culprit.
Again, Thanks for your input.
To Idle Problem
