Boost, big power and failed CAT
What you see here is the core hanging out of the left side of the X pipe
This is on the engine side of the X pipe where you see a bunch of pieces of the core that wasn't able to be expelled.
The CATs I installed into Glens car were made by Dynatech, they use the same cores as Random Tech and others that use a mettalic substrate. In this case from what I can tell the bonding agent failed in the core that is suppose to hold it in place in the shell. The core it self was not clogged up, at least not until I used a rather large screw driver (a three foot long driver) to forcibly remove the core from the X Pipe. When the core blew out of its case, it wedged itself into the Dr. Gas X pipe, basically obstructing the gas flow from the left bank. It later moved down stream a bit to allow some flow. I should say that it flowed fairly well for how it was plugging one side off, as I was able to fry the tires at will up into fourth gear getting on the freeway.
I was rather shocked as to what I found in the exhaust. I am not sure at this time whether I will install another set of DTH CATs or if I will go with another brand.
Thanks for sharing tom. Would u prefer metallic substrate or ceramic on a high perf car. I take my car over 100 mph atleast 3-4 times every week, and will this metallic cat's pass emmission's ?. sami
I was lucky with mine i only had "fairy dust" sprinkling out the back ... That is one for the books i have never seen that....lol
Mo
