Fuel Pressure Regulator Help
Old Dec 17, 2006 | 09:59 AM
BOWLING GREEN's Avatar
BOWLING GREEN
Default Fuel Pressure Regulator Help
I have a 1991 and put an AJ/FPR on it. It will not set, goes to all most 50 and drops right back down. One book says there is an o-ring on one of the inside ports of the regulator / critical . What size? What port should it go on? Car is not at my home so I can't get to it right now to look at it. Thinking we dropped the o-ring out pulling the old diaphragm. OR the book is talking about the two side ports on the hole regulator? WE just took off the top of the regulator not the whole regulator. If not this probable / fuel pump / pulsator? No injector or rail leeks any place. Just will not hold pressure at all. Thanks.
Old Dec 17, 2006 | 10:35 AM
RRT vette's Avatar
RRT vette
Might have installed the diaphram or spring incorrectly.
Old Dec 17, 2006 | 10:55 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When the fuel sustem does not hold prime it can be:
-a line leak
-the FPR leak
-an injector leak
-the pump valve not holding
Did it leak down before you took the AFPR apart?
Had you done any service on the fuel system before the leak down?
Old Dec 17, 2006 | 12:47 PM
BOWLING GREEN
Default MORE info
-a line leak
-the FPR leak
-an injector leak
Doing motor over hall. Had every thing off. Putting on new regulator with adjustable top. It held fuel pressure before we started on the job. No leaks from injectors or fuel rails at all at this time. Leeks off in like 10 seconds. Was there an o-ring on top of one of the ports inside the regulator? Like right under the plunger / valve at the bottom of the regulator ? Think I should have got the 1991 Corvette / GM shop manual for $200.
<Motorbooks workshop 101 projects for your Corvette 1984-1996> talks about the o-ring on page 62. I don't think they are talking about a fuel rail o-ring but an o-ring that goes over one of the ports on the top/ inside of the FPR.
Old Dec 17, 2006 | 12:50 PM
RRT vette's Avatar
RRT vette
Not filmiliar with the AJ/FPR, but my Holley AFPR did not come with a O-ring.
Old Dec 17, 2006 | 01:07 PM
65Z01's Avatar
65Z01
As I recall my HyperTech AFPR just came with the "hat", the plate and special Torx bit.
Can't recall if there was an O-ring on top of the FPR diaphram.
Old Dec 17, 2006 | 02:28 PM
Happydad's Avatar
Happydad
My accel Did'nt have an O-ring either Have you tried to block off or pinch closed the main fuel line (with key on)and watch if it leaks down slower..then block off return line and watch..If it slows down alot or stops check your fuel pump valve..Is there fuel in the Vacuum line of the FPR ??? Just some things to check,,Agent 86 Posted how to do this leak test a few weeks ago Do a search...Good Luck
Old Dec 18, 2006 | 09:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have you checked FPR vac line for fuel ??
Start pinching some fuel lines.
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Oh, and no O ring in my Holley or stock reg.
To Fuel Pressure Regulator Help
