digicluster and fuel system shuts off ????
Old Dec 17, 2006 | 02:54 PM
chillcat's Avatar
chillcat
Default digicluster and fuel system shuts off ????
I've been experiencing a problem with electrical system since yesterday---driving down the road the voltage keeps fluctuating from 13.7-13.1 then when it drops lower the digicluster goes black and the car seems to shut down and then a few seconds later runs back to normal----I have this strong feeling its a Ground problem for the ecm.....I ran a jumper wire from a gx location to "1" ground wire on ecm---INCASE the ecm gx is loose somewhere, but I haven't tapped into the other gx wire (isn't there 2 gx wires for the ecm unit?) black/white wires? obviously the wire i jumped from has not corrected the problem. i don't know where the gx points are for the ecm--back of engine somewhere ?? I have the shop book for my year car, but I can't find the help i need....my car is an 85--Any help please
Old Dec 17, 2006 | 03:50 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Since your digidash goes black with the engine failure, i'm thinking it's more of a global power problem.
Loose ground or + lead somewhere ??
Good luck
Old Dec 17, 2006 | 04:03 PM
chillcat's Avatar
chillcat
weird thing is I noticed yesterday that my AC does not blow cold anymore....it did before, not sure if that has anything to do with this new problem....I have a friend who owns an auto electric shop and he metered my battery and alt and said they are putting out a good 14.2-14.3 volts, when my digicluster was reading like 13.6 SAME time he was checking....
Old Dec 17, 2006 | 04:54 PM
chillcat's Avatar
chillcat
I'm going to take it my friends shop and let them take care of me, was just hoping it was something I could fix without spending too much time on it...opinions are still welcome and i could mention them to him...
Old Dec 17, 2006 | 07:12 PM
AGENT 86's Avatar
AGENT 86
Before seding her away, i would check grounds at DS of block and all connections at power distribution blocks.
Old Dec 17, 2006 | 07:16 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Sounds like a ground problem. I believe the major ground connection is on the left (driver) side above the oil filter on an 85. It's kind of a stinker to get to, and should have about 5 or 6 straps connected to an 18 mm bolt. I'd check all the ground connectors on the engine and the frame, there are several.
Old Dec 17, 2006 | 07:32 PM
rick lambert's Avatar
rick lambert
I was talking to Gordon Killebrew about a problem once and he said low voltage could take the cluster out....find out what's wrong before you end up having to buy a new or rebuilt cluster. it does sound like a ground problem.
Old Dec 17, 2006 | 07:39 PM
chillcat's Avatar
chillcat
the cluster is fine, its already been rebuilt...I'll check the ground pts around the engine if I can lift the car up some I'll get under there...where are the distribution blocks at ?
Old Dec 17, 2006 | 07:45 PM
rick lambert
on the drivers side back of the head there is a ground block (don't need to get under the car) there are a few grounds there, and from there, there is a braided ground strap that goes to the frame rail just in front of the battery.
Old Dec 17, 2006 | 08:15 PM
chillcat's Avatar
chillcat
I think I found the problem and fixed it!!! i was getting ready to swap out the alternator with a 2nd alt I had stored away and I unhooked the power wire harness and noticed the small wire pulled right out of the harness (there are 2 wires in the connector large red wire and a smaller brown wire) so i restripped it and crimped it back in and what do you know!! So far so good on the voltage----But the AC is still a puzzle, blows air, but not cold. the compressor is not kicking in while at idle with ac on. I checked that wire harness and fuse--they check out good....haven't looked in my shop manual yet, but I can say...The Whole ac system has been replaced with new parts and blew icecold air untill i checked it yesterday.....Any opinions on this?
To digicluster and fuel system shuts off ????
