Digital Dash Problem
Old Dec 17, 2006 | 02:58 PM
donandsandra's Avatar
donandsandra
Cruising
Default Digital Dash Problem
Anybody seen a digital dash problem like this before? Ive been pulling my hair out trying to figure this out!!!!!!
I turn the key on the dash display looks great... Start the engine and the cluster goes goofy...
Check the video below.
http://www.youtube.com/watch?v=qdULEgJT8kw
Thanks Don
__________________
Vrooom nothing compares to a VETTE!!!
Save the wave!!!
Old Dec 17, 2006 | 04:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I've not seen that one but maybe you could pull the cluster and clean the contacts with some contact cleaner and check the cluster ground before sending it off for service.
Old Dec 17, 2006 | 04:43 PM
LarryK 87's Avatar
LarryK 87
had a similar problem when i first got mine, it would just go nuts, tach would work backwards, oil pressure was showing 0 etc, pulled the dash apart, and relowed all the connections, and cleaned up all the grounds, problem disappeared completely
Old Dec 17, 2006 | 04:59 PM
RRT vette's Avatar
RRT vette
Yep. Take the dash cluster out and clean all the connections/contacts with CFC electrical cleaner. Make sure everything looks good when you put it back in. Also there are two grounds for the dash cluster. I could be a little wrong without a refrence to follow, but I think one is on the driverside head and the other is under the carpet on the driverside footwell. Others will correct me if wrong. If that doesn't do the trick, you will more than likely need to send it off for service.
Old Dec 17, 2006 | 05:11 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Ignition interference of some sort?
Old Dec 17, 2006 | 07:40 PM
rick lambert's Avatar
rick lambert
I'd bet money it's NOT a ground problem!!!!!!!
I think CC hit it on the head.
Here's what happened to me....same symptoms, everything was pretty much going crazy..and it only happened after I had done a tune up, turns out when I installed a new coil (in the cap) I pinched one of the coil wires..it was actually arcing in there......this may not be your problem..but I'd be putting in a new coil..there alot cheaper than a rebuilt cluster, or at least trouble shoot the coil.
Old Dec 18, 2006 | 09:36 PM
donandsandra
Cruising
Just repaired problem..... It was a bad coil... that was a weird problem...
Thanks Guys for the info!!!! You guys rock!!!!!
Old Dec 19, 2006 | 09:43 AM
cajun86's Avatar
cajun86
http://www.corvettedashclusterservic...0Clusters.html
Old Dec 19, 2006 | 10:03 AM
rick lambert
Glad it was a simple fix....I've got Gordon Killebrews book...no where does it mention checking the coil..unless I over looked it, and I even talked with him when I was having that issue....it just bugged me that it just did it after the tune up...so I doubled checked what I'd done, that's when I found the coil issue. To bad I can't make a sticky, could save guys a few hundred bucks for a $30. repair.
Old Dec 21, 2006 | 11:16 AM
donandsandra
Cruising
If I didnt get the great advice from you guys I would have sent my cluster in and still had the problem.... Thanks Again
Old Dec 21, 2006 | 09:28 PM
Maximus9000's Avatar
Maximus9000
Mine has done that twice just after a tune up, along with a high speed miss.
I'm changing my coil.
Hope that's the fix for both problems.
Is the magnet on the coil supposed to flop around?
Old Dec 21, 2006 | 10:43 PM
CentralCoaster
Mine have all had a little bit of play.
To Digital Dash Problem
