best spark plug LT1
Old Dec 18, 2006 | 09:09 PM
gator79's Avatar
gator79
Default best spark plug LT1
what is the best plug for a stock LT1? and possibly some tips on reaching the drivers side plugs I was going to go back with the stock A/C's
Old Dec 18, 2006 | 09:19 PM
rick96cevette's Avatar
rick96cevette
Can't help you with reaching the driver's side plugs, but I used the Bosch Platinum +4's and so far so good....however, I have read where a lot of people say stick with what the General put in them from the factory.
Old Dec 18, 2006 | 09:26 PM
ZBRA's Avatar
ZBRA
I have used AC Delco Rapidfires in every high perfomance engine I have owned, and never had any problems. That's what'll be going in my new LT1.
I know there are other plugs out there just as good, but Delcos are my preference.
The only plug I have ever had problems out of was a Bosch Platinum. The Bosch Platinums have a very small tip sunk into the ceramic insulation, and it doesn't take anything to foul one out. They probably work well in brand new engines, but don't put them in anything with high mileage.
Old Dec 18, 2006 | 09:29 PM
STL94LT1's Avatar
STL94LT1
Best plug for the LT1: On a budget, NGK TR55. Cost is no object, Denso IT16.
Old Dec 18, 2006 | 10:15 PM
jstkrsn's Avatar
jstkrsn
Default plugs
I also have the Bosch +4's. Haven't had any problems.
Old Dec 18, 2006 | 10:36 PM
RetroTA's Avatar
RetroTA
I put AC Delco's in my 93, Now it idles ROUGH?
Old Dec 19, 2006 | 12:36 AM
Casethecorvetteman's Avatar
Casethecorvetteman
I use the NGK TR55-IX.
Here is a tip for you on plug replacement. Its a piece of ****, couldnt be easier.
Old Dec 19, 2006 | 10:16 AM
Strick's Avatar
Strick
I use the TR55IX from NGK and they work fine. I made a plug wrench from an extra 9/16 box end wrench and welding a short socket to it. Works great on good ole #8.
Oh, some guys have reported that the AC Delco plats sometimes lose their pucks causing a huge gap and rough idle.
Old Dec 19, 2006 | 10:18 AM
rickneworleansla's Avatar
rickneworleansla
I just installed NGK TR6's. The car seems to idle a little better than before. I just changed my plugs last saturday. Check out my other thread.
http://forums.corvetteforum.com/show....php?t=1577296
Old Dec 19, 2006 | 05:50 PM
redcorvettedave's Avatar
redcorvettedave
It's been quite awhile since I've seen a " what's the best" this or that thread!
Old Dec 19, 2006 | 06:07 PM
Lone Ranger's Avatar
Lone Ranger
What about the Autolite double platinums that are clones of the stock AC double platinum plugs? Anyone running those? I think they're Autolite APP106 ?
Old Dec 19, 2006 | 07:56 PM
tlong's Avatar
tlong
I put 40,000 on AC Delco Platinums and replaced with NGK Tr55 IX. The Delcos looked near new with no missing pucks. This car has never stumbled due to ignition. I hammer it occasionally. The NGKs may idle a little bit smoother but performance is the same. They make plasma not just a spark. (That's what the ad said.......)
$60 for the last plugs I'll ever buy for it isn't bad.
Old Dec 19, 2006 | 09:16 PM
Lone Ranger
Double plat would be a longer life plug than iridium, unless its double iridium (iridium to iridium firing).
Old Dec 19, 2006 | 09:20 PM
RRT vette's Avatar
RRT vette
NGK's or AC Delco's for me.
Old Dec 19, 2006 | 10:00 PM
Road Agent's Avatar
Road Agent
Stock is fine!
Old Dec 20, 2006 | 06:29 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
NGK TR55 is what I use in my 383... Any of the TR55 plugs will work. TR55IX, etc...
Old Dec 20, 2006 | 06:30 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Nice engine..
To best spark plug LT1
Old Dec 20, 2006 | 06:54 AM
Casethecorvetteman
Thanks mate
Old Dec 20, 2006 | 07:33 AM
vetteblack's Avatar
vetteblack
Casethecovetteman, very nice engine area. What kind of paint did you use to stand up to the heat on those plastic pieces?
Old Dec 20, 2006 | 08:46 AM
Casethecorvetteman
Thanks mate, was done when i bought the car, id imagine any high temp automotive paint with do the job though
