383
Superram (if I can ever find one)
74219 cam
52mm tb
So what kind of heads would C4 Tech recommend?
I have the .113 on my car now, and heavily porting them would do the trick, but the cost would bring me damn near to brand new heads.
Can anyone with a similiar setup lemme know what you used?
If all they need is porting it may be worth it for the money spent....If you need a valve job, bigger valves etc youd be better off getting a new set of aftermarket heads that are better than a worked over set of 113s ever could be.
