Additional recommended changer when going to a Miniram?
Old Dec 22, 2006 | 10:24 AM
silver86's Avatar
silver86
Default Additional recommended changer when going to a Miniram?
What other changes should be made to my 86E engine if I decide to go with a Miniram install?
Would going to going to hydraulic roller lifters and camshaft be adviseable given the extra useable rpm range? I know that a camshaft is necessary to take advantage of the increase power range, but is it necessary to switch from tappet to H/R?
Any changes I would need to make inside the block? Engine has 134,000 miles, Vortech 10 psi blower and such, but is stock internally.
Old Dec 22, 2006 | 10:33 AM
bogus's Avatar
bogus
wow.
This is opening a can of worms...
If you are doing all of that, I would go ahead and build up a one piece rear main block. Seriously. It will have the hydraulic roller lifters and aluminum heads.
Then you can build the internals to support that Vortec... I can't imagine what your ring lands and grooves must look like...
Old Dec 22, 2006 | 10:58 AM
silver86's Avatar
silver86
I would rather not pull the engine (don't ask me why, I've done it before, just such a hassle). I will need to switch to forged pistons at that rpm (12 psi with this pulley), but would like to keep the stock C/R of 9.0:1. Naturally, I would hone the cylinders at that time. That intake, with this blower, should yield around 525 chp.
I may even do some slight porting on the stock heads, and throw on some 1.600" exhaust vavles. I really didn't know if the tappet style lifter would efficiently support that type of rpm (+/- 6200). I have a new set already, with springs, so I just wanted to be sure.
Any recommendations for a good pistion set?
Old Dec 22, 2006 | 11:02 AM
Pete K's Avatar
Pete K
I have run hydraulic flat tappet stuff to 6500 with the proper valvertrain.
Hydraulic roller (retro fit) is flat out better than a flat tappet though. If the budget will allow it, it should be a worthwhile swap. I try to use the retro stuff, even in a 1 pc seal roller block. Factory gm roller lifters are huge and heavy.
Old Dec 22, 2006 | 11:36 AM
silver86's Avatar
silver86
Ah, Pete, since you're here anyway, it has been recommeded that I may need to switch to a blueprinted A-4 tranny. Is that something that you could perform to my stocker? It probably needs a rebuild anyway.
Old Dec 22, 2006 | 12:56 PM
Pete K's Avatar
Pete K
Absolutely. I am a bit overwhelmed with builds at the moment, but I can help in the near (or distant) future.
Old Dec 22, 2006 | 01:26 PM
silver86's Avatar
silver86
Probably would be a few months.
Old Dec 22, 2006 | 02:42 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
What about heads?
The blower can overcome a lot flow limits from your heads but better couldn't hurt, especially since the air is going to move through the intake much better. And with the blower you could probably achieve great results with a nice set of inexpensive iron units from Dart or Brodix. Of course if the budget allows you could go way over that, but it may not be necessary. (I am assuming you have untouched early 86 iron heads)
These would also go a long way towards keeping up with MR's ability to flow at higher revs.
Old Dec 22, 2006 | 10:48 PM
vader86's Avatar
vader86
my website has my opinion on it
i think it needs a whole reworked bottom end to last with what you have in mind
no, a roller is not necessary....you can get a tappet grind
Old Dec 23, 2006 | 09:54 AM
silver86's Avatar
silver86
I think this is the route I'm going to go, and skip the MiniRam install. Plus, I can add heads this way! I already have a tappet cam (albeit with 112 lobe sep, maybe a little too much for the blower), and will probably upgrade to a nice set of 1.6 rr (have 1.6 tappets on there now), install some large tube runners (have ported plenum, BM intake, and 52mm TB now, but with stock runners), and come DOWN from 42# to 30# on my injector size.
All of this, of course, depends on my compression test later today (found my PCV popped out of my valve cover). Thanks for all the suggestions.
To Additional recommended changer when going to a Miniram?
