What would you replace / upgrade?
Old Dec 22, 2006 | 03:25 PM
johnash's Avatar
johnash
Default What would you replace / upgrade?
Hello all!
This summer, I bought a powder coating system, and started practicing. I’ve finally gotten good enough that I’m going to start powder coating some parts on the ’89. I’m going to do the intake runners, plenum and the valve covers first, and then maybe move on to some other parts.
While I have the plenum, runners, and valve covers off, I’m wondering what else I should replace / update.
I’m not a mechanic, but with the help from this forum I’ve gotten my hands dirty on a project or two. I was thinking that the valve seals should probably be replaced while I have things apart. The car has 135k miles on it, what else should I replace while I have things apart? I’m mostly concerned with reliability, but extra performance would be great too as long as it doesn’t cost too much!
So, what would you do? Any suggestions?
Thanks!
--- John
Old Dec 22, 2006 | 03:37 PM
B!@cK 86 V3tt3's Avatar
B!@cK 86 V3tt3
Originally Posted by johnash
Hello all!
Thanks!
--- John
If your inferring to actual "motor/performance parts" since you have the valve covers off....heads, springs, roller rockers....I dont know if thats what your specifying though. Good luck with your project.
Old Dec 22, 2006 | 03:40 PM
johnash's Avatar
johnash
I don't think I want to get into doing the heads yet, but springs and roller rockers might fit in the budget.
Thanks for the ideas!
Old Dec 22, 2006 | 04:02 PM
Frizlefrak's Avatar
Frizlefrak
Hello all!
Thanks!
--- John
Here's a suggestion....run an ad in the local paper that you do powdercoating, undercut the competition on price, do better quality than them and watch the money roll in.
OH....you mean on YOUR car.
Mechanically, with over 100K, replace your timing chain if that hasn't already been done. Yeah, I know it's not a "performance mod", but really it is. If the chain is original, it's sloppy, which is costing you power in the form of lost ignition advance.
I replaced mine at 143K after my harmonic balancer disintegrated and did the macarena for a couple thousand revolutions and took out the timing cover seal in the process. I figured I may as well replace the chain since the cover had to come off anyway. WHAT A DIFFERENCE!
Smoother idle, SOTP power difference particularly in the low RPM range, better vacuum signal, better fuel economy, all around better running engine.
If you're gonna pull the valve covers, not a bad time to replace valve seals and adjust the valves too.
What you decide to do power wise is directly proportionate to the size of your wallet and the amount of free time you have.
Have fun.
Old Dec 22, 2006 | 04:13 PM
johnash's Avatar
johnash
I would love to, but I barely have time to do my own work!
As for the timing chain, great suggestion! I would have never thought of that!
Thanks!
Old Dec 22, 2006 | 04:33 PM
tntcorvette's Avatar
tntcorvette
replace the egr thing that sits on top of the base manifold. Not sure if it is the same as the 85 but if it is, replace it and the wire that runs to it.
Old Dec 23, 2006 | 09:43 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I agree with the timing chain suggestion. Mine was so loose that my knock counts were similar to a rod bearing failure.
Valve seals and new springs are worth the time also.
Old Dec 23, 2006 | 09:07 PM
johnash's Avatar
johnash
Default Timing chain
Wow! Ok, I guess I have to replace the timing chain / gears now!
How hard of a job is this? I'm not a mechanic, but I have done injectors, and some other small work. Is this something a wannabe mechanic can handle?
Old Dec 23, 2006 | 10:21 PM
Trog's Avatar
Trog
Timing chain, valve springs. water pump while its off to get to the chain.
You can do it. rent or buy a damper puller/installer, gear puller for the bottom gear & the rest is hand tools.
You "should" drop the oil pan to release the bottom of the timing cover.
If you haven't bought one, get a Helms FSM (field service manual). It will save you the initial cost many times over.
To What would you replace / upgrade?
