Still Rough idle.... Thoughts...
Old Sep 28, 2001 | 06:45 PM
Nomar116's Avatar
Nomar116
Default Still Rough idle.... Thoughts...
I got a timing light, and found the timing to be at 16 deg Advanced, I retarded it down to 8 and the car now holds an idle....
It still seems as though sometimes after idleing for a while it is very sluggish off the line, sometimes chocks and wants to die.... Im wondering if 8 is too much, I had no idea such a MINUTE difference in the distributor effected drivability so severely.
I also have the problem with the fuel pressure regulator being broken, and leaking vacuum badly as well as effecting the fuel pressure.
Paul
Old Sep 28, 2001 | 07:42 PM
weekendwrench's Avatar
weekendwrench
Default Re: Still Rough idle.... Thoughts... (Nomar116)
I wouldn't start replacing any parts until your pressure regulator is fixed. Both a vacuum leak and low fuel pressure could be your problem.
P.S. 8 degrees is a big difference in engine timing. Did you disconnect the brown est wire before you set the timing?
Old Sep 28, 2001 | 10:58 PM
Nomar116's Avatar
Nomar116
Default Re: Still Rough idle.... Thoughts... (weekendwrench)
I set the timing with that wire disconnected. Its at 8 but I think I want to put it at 6... it still stalls right at startup. Whats the right timing though for my LT4 Hot cam.
Paul
Old Sep 29, 2001 | 09:25 AM
Aaron's 87's Avatar
Aaron's 87
You better fix all your vacuum leaks with the MAP car. Have you made a custom chip yet? Good luck without one.
To Still Rough idle.... Thoughts...
