Stock Lifter Question
Old Dec 27, 2006 | 05:01 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Default Stock Lifter Question
Pardon if this has been posted before. I did a advanced search and didn't find any answers to my specific question so here goes. Also, I think I already know the answer but thought I'd throw it out to the experts here on the Forum first.
I am preparing to install a LT4 hot cam in my 94LT1 in a while and I'm still gathering parts. I currently have 150,000 miles on the stock motor. I'm not fanatical about oil changes but do them fairly regularly and use Amsoil synthetic. do I need to replace the stock lifters with the lifter kit available from GM performance parts?
I don't want to buy the whole Hot Cam kit because I already have a set of ported heads with new springs and valves installed. All I really think I would absolutely need are the 1.6 rockers. What is the consensus? Pushrods are cheap, so I'll probably go that way but could save a bunch by reusing lifters if I could.
Old Dec 27, 2006 | 06:18 PM
STL94LT1's Avatar
STL94LT1
With 150,000 miles on the car you definately need to replace the stock lifters.
You can get the complete GMPP lifter kit from Van Devere Olds for ~$200.
Dal @ Van Devere 1-800-362-9494
Old Dec 27, 2006 | 07:55 PM
jsavoy's Avatar
jsavoy
Here's my $.02. I found myself in the same position a few months ago. I purchased the Hot Cam kit. The reason, the cam by itself was @ $210 and the GM Perf. roller rockers were @ $320 = quick math @ $530. The kit is $550, I didn't need the springs, keepers, guides, etc... but I sold them to someone locally and recouped some $$$-always someone w/ a F-body around . Pushrods with 150K? your call--it may be nothing wrong with them. I know you'll inspect them for wear on the ball ends, etc... but visually you're not going to pick up fatigue. I'd change them but I'm a bit picky when it comes to putting things back together. It must be the aircraft mechanic part of me, I do tend to replace more than some. Good luck, let us know what you decide.
Old Dec 27, 2006 | 07:59 PM
6spd95's Avatar
6spd95
with 150,000 I would thow in a new set. even if the stock ones still look good.
Old Dec 27, 2006 | 09:00 PM
Warp8's Avatar
Warp8
Yes, Yes, Yes. Why put relatively inexpensive parts with 150,00 miles back in your swap?
Old Dec 27, 2006 | 09:16 PM
biggrizzly's Avatar
biggrizzly
Thanks guys, this is the answer I thought I'd get, and it does make sense to me. But, I thought it might be worth the question. You never know.
I guess it does make sense to buy the whole kit and sell the springs.
Old Dec 30, 2006 | 02:15 PM
TankerVette's Avatar
TankerVette
look into rhodes v-max, please.
To Stock Lifter Question
