Does anyone have or know where I can get the pinout descriptions for the 1984 dash instrument cluster, or any technical specs on it (or the cluster) at all?
Thanks, Dan
Hi Dan,
Are you referring to the 32 Pin Connector or the 24 Pin Connector?
The 32 Pin Connector looks like power, ground , sensor and a few switched inputs.
Switched power, lamp briteness control and tach signal also come into this connector.
THe only 'fancy' input I see is the MPG serial data line that would have to go to the ECM.
All the rest looks like plain 'vanilla' mostly analog inputs with an interface thrown in for the cruise control.
Your TV remote control is probably more sophisticated than our digital dash.
Gordon K's book may be just what you're looking for.
