How do I pull the LTPWS bulb?
Old Sep 29, 2001 | 11:10 AM
Flylow's Avatar
Flylow
Default How do I pull the LTPWS bulb?
Does anyone have instructions on how to do it in a 92 Vette?
Old Sep 29, 2001 | 01:58 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: How do I pull the LTPWS bulb? (Flylow)
OK, I'll ask, what is it?
Old Sep 29, 2001 | 04:47 PM
ZEEEE06's Avatar
ZEEEE06
From: PERCUSSIVE MAINTENANCE: The art of whacking the crap out of an electronic device to get it to work.
Default Re: How do I pull the LTPWS bulb? (65Z01)
Low Tire Pressure Warning System
Old Sep 29, 2001 | 05:10 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: How do I pull the LTPWS bulb? (ZEEEE 06)
when you take the cover off the front of the display there are a bunch of "compartments" which hold the bulbs, all you should need to do is remove the bulb with a pair of pliars
Old Sep 29, 2001 | 07:22 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
on my '96 I just pulled the #32 fuse on the r/s dash fuse panel. This also kills the cruise control but who cares.
Old Sep 29, 2001 | 10:35 PM
vanduker's Avatar
vanduker
To troubleshoot:
http://www.hashmarks.com/techtips/service_ltpws.htm
To Remove Bulb:
http://www.hashmarks.com/techtips/remove_ltpws_bulb.htm
Mark
Old Sep 30, 2001 | 05:17 PM
Flylow's Avatar
Flylow
Default Re: How do I pull the LTPWS bulb? (vanduker)
vanduker
Thank you. Your post had the info I was looking for. The bulbs are gone. Its a pretty simple job when you have the proper info.
To How do I pull the LTPWS bulb?
