L98 Water Pump
Old Dec 30, 2006 | 05:49 PM
Corvette Chris's Avatar
Corvette Chris
Default L98 Water Pump
This seems like a dumb question to me, but..
Is there a difference between a "Corvette" water pump ('86 here) and a short small block Chevy water pump? I would think there would be, hence why some catalogs (ala Summit) lists specific pumps for the Corvette. But the other part of me thinks it's a gimmick to get more money out of my wallet.
Thoughts?
Old Dec 30, 2006 | 07:47 PM
86GoldProject's Avatar
86GoldProject
Most small blocks use standard rotation pumps where as corvettes use reverse rotation pumps, its because of the belt routing. Basically the impellers in the pumps face a different direction, if you use the incorrect pump you will have overheating issues due to little to no coolant flow.
Old Dec 30, 2006 | 08:17 PM
Corvette Chris
Ahhh, OK, that makes sense. I knew the LT1/LT4s were reverse rotation, but was not aware the L98s and other engines were. Thanks!
Old Dec 30, 2006 | 08:19 PM
C4Techie's Avatar
C4Techie
There are only so many basic SBC water pumps. All C4s with Gen I engines take a "long" water pump. All serpentine belt (as apposed to v belt) driven water pumps take the "reverse rotation" (ccw) pumps.
Old Dec 30, 2006 | 08:26 PM
C4Techie's Avatar
C4Techie
It doesn't make sense. Because it isn't the case. The Gen II (LTx) engines don't necessarily have a reverse rotation water pump. Their pumps are driven off of the camshaft, not a belt. The Gen II engines have reverse flow cooling systems. That is different than a reverse rotation pump.
Old Dec 30, 2006 | 08:47 PM
Maximus9000's Avatar
Maximus9000
Belt under pulley, belt over pulley!
Old Dec 30, 2006 | 08:55 PM
danno85's Avatar
danno85
The Corvette water pump (for L98) has a slightly larger diameter shaft and bearing assembly, which makes it different than other small block short pumps.
Old Dec 30, 2006 | 08:56 PM
86GoldProject
C4's take a short water pump.
Old Dec 30, 2006 | 11:36 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I 'beeve' both my C4's have the short pump.
BTW.........
I've taken some of these pumps apart and the impeller had straight blades on them sooooooo.....
The the ones I looked at (not saying ALL impellers are the same) didn't have a 'directional bias' as to pumping 'better' in one direction because it was a Vette pump vs. a standard SBC pump.
I've also seen curved blade impellers on some pumps.
Someone mentioned above the pump wouldn't pump as well if a standard pump is used instead of a Vette specific pump.
THat's highly possible in some cases but it wasn't the case with a couple of my Vette pumps.
I pulled the rear cover on two C4 pumps I replaced and they both had straight blades, to my surprise.
Anybody collaborate on this with your pumps?????
Just a 'FYI'.........
Oh, I'm running a Stewart 'High Flo' pump on my '91 (Vette Specific) and it didn't help it run ANY cooler than the leaky pump it replaced.
It's ok in the cooler months but in the hotter ones 240~250* engine temps make it be a PITA.
I didn't pull the cover on it to see what type impeller it had.
AS always, YMMV..
To L98 Water Pump
