Rev Limiter ..
Old Dec 30, 2006 | 11:13 PM
#70SM2's Avatar
#70SM2
Default Rev Limiter ..
Any good idea's about a rev limiter on my new 355.. I mostly AutoCross the car, so I really can't pay to much attention to the tach. The new motor is 355ci. 420hp. Trick Flow, rev's really quick, but hav found it best to shift at 5800rpm. .. I would like to find an inexpensive but reliable method to limit the rpm., so I don't blow it up? any idea's ..
Old Dec 30, 2006 | 11:18 PM
STL94LT1's Avatar
STL94LT1
Can't you reset your factory fuel cut-off. Also, a shift-light will help you know when to shift without looking at the tach.
Old Dec 30, 2006 | 11:30 PM
#70SM2's Avatar
#70SM2
Default Factory fuel cut-off ..
That would be interesting, any idea how that would be done? The problem is it rev's so fast in first, I'm afraid I'll blow it .. this is the 3d. motor .. AutoCross is jus to intense to watch the tach .. I do plan to install a shift light though..
Old Dec 30, 2006 | 11:34 PM
85vet's Avatar
85vet
Cruise-In V Veteran
chip w/ rev limit set or msd 6al.
Old Dec 30, 2006 | 11:39 PM
#70SM2's Avatar
#70SM2
Default msd 6al ??
hmm. what's that in English? sorry.. does that have to do with the ignition?
Old Dec 31, 2006 | 12:01 AM
85vet's Avatar
85vet
Cruise-In V Veteran
I saw that you have an 86 and I am not sure if your ecm has a rev limit set on it. If so you need a new chip programmed with the rev limiter set.
The msd6al is:
http://store.summitracing.com/partde...5&autoview=sku
Sorry,
To Rev Limiter ..
