Another SuperRam Question
Old Dec 31, 2006 | 01:09 PM
csheerin's Avatar
csheerin
Default Another SuperRam Question
I am finally putting this thing back together after a year.
My question is on the back side of the plenum I have 2 holes shown below. I figure that one is for the brake booster vac but what's the other one for on the right side in this pic?
Old Dec 31, 2006 | 01:26 PM
tequilaboy's Avatar
tequilaboy
I think the third port is intended for the MAP sensor on SD cars.
I Just checked mine.
The third port as shown in your pics is plugged with a simple hex socket (allen head) pipe plug. There is a smaller hole between the other 2 vacuum ports which is also plugged with a 6 mm bolt. I believe the 6mm hole is also for the MAP sensor (maybe the mounting hole).
Old Dec 31, 2006 | 07:13 PM
Kool88vette's Avatar
Kool88vette
I just check my SR. I have a brass fitting on the drivers side and a vacuum line that goes to the brake booster. The other side on my SR is blocked off.
Old Dec 31, 2006 | 09:41 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
To a tee
Old Jan 1, 2007 | 02:11 PM
csheerin's Avatar
csheerin
Thanks guys...hopefully finish it up today!
Old Jan 1, 2007 | 11:14 PM
sami85L98's Avatar
sami85L98
U need to check this thread too: he just finished SR install and posted pretty nice pics.
http://forums.corvetteforum.com/show....php?t=1585954
To Another SuperRam Question
