Timing cover ?
Old Dec 31, 2006 | 05:59 PM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
Default Timing cover ?
Can you remove timing cover without loosening oil pan?
Old Dec 31, 2006 | 07:04 PM
pletzvet's Avatar
pletzvet
You might be able to get the cover off, but you won't get it back on properly without lowering the front of the oil pan. However, it is possible to grind a little bit off the ends of the inside lip of the TC cover to get it back into the right position around the oil pan, then use some extra RTV sealer to take care of the gap. Now, I've seen a 2 piece TC cover on ebay, designed so you can put the piece with the inside lip on first and then just slide the TC cover with seal installed over the snout of the crank. I don't know how well these work and would be interested to hear from anyone who has used the 2 piece TC cover.
Old Dec 31, 2006 | 07:59 PM
STL94LT1's Avatar
STL94LT1
It's really not that hard to loosen the oil pan, well worh the effort to avoid oil leaks.
Old Jan 1, 2007 | 12:03 AM
BrassRing's Avatar
BrassRing
Ah...good question. I've been wondering the same thing. Tomorrow's plan is to pull the TC cover. Harmonic Balancer is almost off. I'm trying to do it without disconncting the steering rack lines. Loosenig the oil pan looked like a pain because of the cross memeber, but I'll have to take another look. When you re-seated the oil pan, did you use a new gasket or just shoot some RTV in there?
Old Jan 1, 2007 | 08:40 AM
DRAKEFAMILY2
I'm not sure yet if i need to replace TC yet but i thought the easiest way to get off was loosen oil pan bolts, just checking. I got the balancer off without removing any lines, but i did have to cut about 2 inches off the long bolt for the puller. I shortened mine so i could get a wrench on the end of it. It was a PITA to get off.
Old Jan 1, 2007 | 01:15 PM
AKS Racing's Avatar
AKS Racing
Use same oil pan gasket, but use some RTV to ensure that everything seals well. You should not have to remove any of the rack lines, and the oil pan bolts are not so bad with a 1/4 drive and universal joints.
Aaron
To Timing cover ?
