Pulling power strng. pulley...help!
Old Jan 1, 2007 | 04:27 PM
joseph p's Avatar
joseph p
Default Pulling power strng. pulley...help!
Does anyone know of a way to pull the pulley off the pump aside from using "a pwer steering pulley puller?"
Thought maybe someone here might have a quick, simple method.
Old Jan 1, 2007 | 04:35 PM
edcmat-l1's Avatar
edcmat-l1
nope.....proper puller
Old Jan 1, 2007 | 04:59 PM
92PGC's Avatar
92PGC
I don't know of any other way either. I had to buy a puller when I was working on my 92. It was just as cheap to buy a lower end puller as it was to rent one. Bought mine from a local speed shop for around $35. Some foreign made brand but good enough for the weekend warrior.
Where is Hawthorne, NJ ?
Old Jan 1, 2007 | 09:33 PM
joseph p's Avatar
joseph p
"Where is Hawthorne, NJ ?"....
Northeast NJ, near Paterson and Paramus.
Old Jan 1, 2007 | 09:48 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
No other way to get it off without bending the pulley or cracking it if its plastic.I bought the proper puller/installer tool and it worked great to remove and replace.
Old Jan 1, 2007 | 09:51 PM
joseph p's Avatar
joseph p
Any suggestion of a particular tool and where it is available?
Thank
Old Jan 1, 2007 | 09:53 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Any local parts supplier will have it, it's a very common puller.
Pete K's Avatar
Pete K
Most of the chain stores such as Autozone, will rent them for free. Leave a deposit and get it back when you return the puller.
Old Jan 1, 2007 | 10:12 PM
tonymax2's Avatar
tonymax2
I also use the local Autozones to "rent" special tools. Got a bunch for the last engine overhaul. Here, you "buy" it with a credit card (or cash, I guess) and then return it when done for a credit on the card. I don't have to return them to the same store and they haven't screwed-up my card to date. I think it's one of the best programs I've ever seen, gets me comming there for other stuff (the intent, of course) but do check the stuff before you leave the store. Sometimes the last guy forgot to return a special bolt, nut or whatcamacallit that goes with it.
Old Jan 1, 2007 | 10:54 PM
sami85L98's Avatar
sami85L98
Thats what i did, return for full refund. Only autozone and advance rent it others dont.
To Pulling power strng. pulley...help!
