'96 Fuel Filter Change
There's got to be an easier way.
the fuel filter.
Loosen the fuel filter clamp.
Then, use a fuel line disconnect tool from the fuel line on top of the engine with a fuel line release tool and either pull straight up or pull out from the bottom (the fuel line and filter attached). Disconnect the line that is attached to the fuel filter and not the return fuel line.
The fuel line release tool is plastic and cost around $9.00 at any auto parts store.
Before doing the above, disconnect the neg. battery terminal. Take the gas cap off to release the pressure and at the fuel rail valve, relieve all the pressure.
Last edited by runner140*; Jan 2, 2007 at 11:57 AM. Reason: Additional information.....
the fuel filter.
I pulled mine out from the bottom. The convertibles are more difficult. I tried Jiffy Lube once and they would not do it. I did it myself the following weekend then went back and told them how it's done. Just don't forget to relieve that pressure.
The KEY is:
Follow the fuel line from the engine to the bracket attached to the hvac box and unhook it there. Then follow the lines along the bottom of the car aft of the filter and disconnect those backets. Now you will have plenty of movement to pull the filter down and disconnect. The lines at the engine are very flexible and allow the filter to be moved around quite a bit.
Be prepared to immediately put the new filter on even after you have relieved the pressure. The fuel continues to run out. It may be easier if the tank is not full.
Good Luck!!!!
