24# injectors
Old Sep 30, 2001 | 12:22 AM
jeffie86/96's Avatar
jeffie86/96
Default 24# injectors
I am planning to install new injectors in my warmed over 360 (cam,heads,rockers,rods,pistons), I was planning to use Accel 24# units . Will they work well on my stock induction system? I did a site search and found very conflicting information and opinion. thanks Jeffie :chevy :flag
Old Sep 30, 2001 | 12:22 PM
jeffie86/96
Default Re: 24# injectors (jeffie86/96)
By the way my engine will be equipped with Edelbrock performer heads, Crane 2040 cam, roller rockers, 10-1 pistons, but I do not have any dyno to check it on. Jeffie :chevy
Old Sep 30, 2001 | 03:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you have an idea of what HP to expect there is a table on my site with FP settings and it'll tell you if those injectors will flow enough.
To get a rough idea of HP from your setup, you've got mail on results of some 350cid L98 mods.
Old Sep 30, 2001 | 04:16 PM
Beach Bum's Avatar
Beach Bum
They'll work perfectly.
good luck
Beach
Old Oct 1, 2001 | 07:13 PM
jeffie86/96
Default Re: 24# injectors (Beach Bum)
OK so I don't need to install an AFPR. Now what about the Accel injectors being rated at 24# at 36psi? isn't the stock system set to a higher pressure than that and how will it affect my tuning? Jeffie :smash:
Old Oct 1, 2001 | 10:13 PM
1MoorTym's Avatar
1MoorTym
From what I've been told, the Accel injectors are rated at the GM (higher - as in non- Ford) pressure.
Old Oct 2, 2001 | 01:18 PM
White Lightning's Avatar
White Lightning
I have the Accel 24# injectors on my 89, and they're working quite well, but you might consider using the Rochesters instead. A local speed shop here in Sacramento prefers them over the Accels and the Lucas injectors, and they're only $6 or so more per unit than the Accels.
I don't remember why they preferred them, because my brother was the one who found out and told me about it *after* I had already purchased and installed the Accels. :rolleyes:
-WL
I miss my Ford ... but my aim is getting better.
Old Oct 2, 2001 | 07:45 PM
jeffie86/96
Default Re: 24# injectors (White Lightning)
I believe I will be going with the 24# Accel units just because they are available from Summit and I have been doing a lot of business with them lately. Thanks to Eveybody for their help. I want to get the car together as soon as possible but my buddy wants to polish every bolt and take 6 months to do it, hopefully we will come to a happy medium. Jeffie :cool:
To 24# injectors
