Code 42
Old Jan 3, 2007 | 06:44 AM
Sirwilliam1229's Avatar
Sirwilliam1229
Default Code 42
My 89 has been possessed with rough idling problems. I've check for vaccuum leaks, replaced leaking injectors, and have thrown alot of money at it. I was not getting any engine lights, but I just decided to check for code anyway. Upon checking, I was given a code 42. I the replaced the electronic spark module (Little device under the rotor cap). $59.00 later, I still have the code 42. This car has a serious grip on my wallet, please help!!!
Sirwilliam1229
Default Code 42
Daily Christian Wisdom
I am not where I need to be, but thank God I am not where I used to be.
-Joyce Meyers
Old Jan 3, 2007 | 07:03 AM
RRT vette's Avatar
RRT vette
Post #3 and #4 should help.
http://forums.corvetteforum.com/show....php?t=1495514
Old Jan 3, 2007 | 07:11 AM
1988redvette's Avatar
1988redvette
RRT vette is a very helpful guy. He has given me great advice on more than one occassion.
Definately check that est connector. Unplug it and reconnect it.
I had the same code last summer that wouldn't go away until I removed the ecm computer (under the passenger's side dash) and disconnected the wires as well as removed the chip and put it back it. I haven't had a code 42 in a while. I am convinced that it is either the wiring that plugs into the ecm or ecm itself.
When you are done checking the wires, remove the negative from the battery to clear the codes, and reconnect.
I feel your pain. God bless.
Old Jan 3, 2007 | 07:57 AM
mech259's Avatar
mech259
4th Gear
Code 42 could be a couple of other things. ECM has seen that you Electronic Spark Control is not working properly. Could be the Knock Sensor, on the passenger side of the block, or the ESC module, passenger side by the blower motor. The EST connector is for setting base timing, unplug it, set timing, and then plug it back in. Then clear codes. I bet your problem is either knock sensor or module.
Old Jan 3, 2007 | 08:11 AM
Sirwilliam1229
Thanks! I will try disconnecting the wire and then reconnecting it.
Old Jan 3, 2007 | 09:15 AM
RRT vette's Avatar
RRT vette
Sirwilliam1229, looks like you will need a good ohm meter ($10 at walmart) or VOM ($20 at walmart) and a test light ($5 at walmart) to really figure this code out. You will also need to pull the ECM from under the passenger side dash.
Look under the pass dash at the hush panel. You will need to remove three philips head screws to drop the hush panel and disconnect the light. Move some of the wiring out of the way and you will see a tan bracket with two 10mm bolts. This is what hold the ECM in place. Remove the bolts and the bracket will fall down. Gently pull on the ECM and it will come out. You will be working with the white wire (D4 the EST wire) on the larger of the two ECM connectors (32 pin). Follow the pdf from AGENT 86 in the link I provided. A pic of the location and description of the EST wire is in your thread in Scan and Tune section. Remember to reset the ECM by disconnecting the battery or pulling the ECM fuse when you think you have it figured out. Start the engine and let it run for at least one minute to see if the code is gone or reappears.
Chris, thanks for the kind words...did you ever figure out your fuel problem?
Old Jan 3, 2007 | 01:09 PM
SunCr's Avatar
SunCr
Assuming your Check Engine Light is working, the Code is History; ie, left over from whenever or whomever last checked the timing (and if you are in an Emissions State like CA where they check timing) leftover from your last smog check. Clear it and if it doesn't come back, you've solved the problem. Otherwise, do the easy stuff first and make sure that your Check Engine Light is working. Should be a bulb check everytime you turn on the key. Disconnect the TPS with it running and verify that it will spit out a 22. Inspect the barrel plug connector (some have posted that they've crumbled with age) and wiring. Make sure the Prom is fully seated (especially if you've replaced the ECM) - remove and reinstall.
As to your rough idle, check compression on #7; inspect the spark plug to make sure it looks like #5 and that there's no rust on the threads.
Old Jan 3, 2007 | 02:13 PM
Sirwilliam1229
Great Info guys!
Old Jan 3, 2007 | 02:33 PM
Damien89's Avatar
Damien89
Hi man our vette had code 42 too! we changed esc module, injectors etc etc last thing we checked was the ecm. I borrowed one from a friend and it started right up. Please check the ecm especially if your finding the spark plugs soaked with fuel.
Old Jan 3, 2007 | 05:16 PM
SunCr's Avatar
SunCr
Hardly necessary unless there's a Steady Check Engine Light or no Light at all.
Old Jan 3, 2007 | 05:22 PM
RRT vette's Avatar
RRT vette
Yep, the ECM is usually the last on the list as far as it being bad, but it happens. You will have to troubleshoot to find out the real cause, if the EST connection is good.
To Code 42
