I just bought an 88 with the 4+3 transmission. When i'm at cruise, and I get on the throttle the clutch slips (the rpms spike). The clutch pedal feels normal. Any ideas on what would could cause this?
Does the same thing happen regardless of whether or not you are using the OD?
The OD unit will kick down (go out of OD) with 75% throttle and RPM is below 2500. This is the case in 2nd, 3rd, and 4th gears with the OD engaged. This should feel very much like the kickdown with an automatic tranny.
If the RMP incerease is gradual with only a light increase in throttle, the chances are the clutch disc is worn. Do you get any gear grinding when going into reverse? That's usually the best indication of a worn clutch.
The clutch is hydraulically operated and unless there is air in the system, you should not feel anything different in the pedal even if the clutch is worn. There is no adjustment in the clutch.
Sounds like I have a worn clutch. The slippage occurs with the overdrive on or off. The rpm increases whenever the gas pedal is punched hard and before the car begins to accelerate. Normal acceleration and shifting is fine, and no problems noticed in reverse. I guess the hydraulic clutch explains why the pedal play feels normal. I was hoping the fix would be just an adjustment. Thanks for the info.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yes, sounds like the clutch. It will happen more in the higher gears since the clutch usually transmits more torque there during normal driving than in the lower gears.
