Pulley elimination???
Old Jan 4, 2007 | 04:14 PM
joseph p's Avatar
joseph p
Default Pulley elimination???
OK, this is not about a C4 but it is about a C4 engine....
My son's friend put an '85 L98 into a S10 Blazer. He wants to eliminate the AC and the air pump, but still retain a serpentine system. Can this be done and what belt would he use? Saving space is of prime importance!
Old Jan 4, 2007 | 04:23 PM
C409's Avatar
C409
Default pulleys
Hey....I have an air pump eliminator kit on my vette that was purchased from Breathless performance in South FL ...I know that an AC eliminator is available but don't know the Mfr. There are a couple of these currently on Ebay for around $50 . These units both have pulleys and use the original belt . However ,that is when installed on a Corvette , if your application requires some modification , you would likely need to change the belt size . Good Luck !
