LT1 Water Pump drive
Old Jan 4, 2007 | 11:09 PM
LannyL81's Avatar
LannyL81
Default LT1 Water Pump drive
In the LT1 engine, what is it that drives the water pump? There is a water pump drive unit that installs above the camshaft but I do do not have enough information to see what/how it is driven....how is it?
Old Jan 4, 2007 | 11:33 PM
STL94LT1's Avatar
STL94LT1
The water pump drive is driven from the top timing gear.
Old Jan 5, 2007 | 08:42 AM
LannyL81's Avatar
LannyL81
Okay...got it....that was the picture I was missing. So the cam gear has teeth on the backside that engage the water pump drive, correct?
The manual just does not show a good clear picture of this.
Thanks for the picture and the info.
Old Jan 5, 2007 | 09:23 AM
MikeC4's Avatar
MikeC4
There is a female coupler that connects the drive gear shaft from the engine block to the drive gear on the WP
Old Jan 5, 2007 | 09:49 AM
STL94LT1's Avatar
STL94LT1
Yes.
Old Jan 5, 2007 | 09:15 PM
USCG's Avatar
USCG
Don't overlook the shaft seal (Water pump AND opti). Autozone or probably any parts store for $5-10.
To LT1 Water Pump drive
