uncontrollable horn
Old Jan 5, 2007 | 08:38 AM
Grenkepr's Avatar
Grenkepr
Default uncontrollable horn
Can anyone tell me how to disable my alarm system without disableling the horn. My horn will go off anytime, anywhere. Sometimes it will be weeks between going off and sometimes hrs. There is no apparent reason for setting it off. It may go off at three in the morning setting in the garage. Have had this problem for yrs. and have just kept horn unplugged. Car is torn down for the winter and would sure like to fix it now. I've tried pulling the fuse in the center control panel, but that also disables the horn. Any ideas from you experts? '88 L-98 coupe 4+3.
Old Jan 5, 2007 | 09:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There are 2 black wires going to terminal 1 of the horn relay. One of them is from alarm and one from horn switch. Figure out which one is from horn and cut the other.
Old Jan 5, 2007 | 11:01 AM
rhelwood's Avatar
rhelwood
I had the same issue. It was solved by replacing the horn contact wire inside the horn button on the steering wheel. Take the horn button off and remove the contact wire the next time it goes off. A cheap fix if it is it.
http://www.ecklers.com/product.asp?p...dept%5Fid=1714
Good Luck
Old Jan 5, 2007 | 11:05 AM
87 rag's Avatar
87 rag
If it goes off at 3 in the morning I'm surprised your neighbors haven't disconnected it already.
Old Jan 5, 2007 | 02:37 PM
Grenkepr's Avatar
Grenkepr
Have you got any ideas on how to figure out which is which ? I have located the two black wires you are talking about, but can barely get to them. Greatly appreciate your help.
Old Jan 5, 2007 | 03:22 PM
AGENT 86's Avatar
AGENT 86
Remove one and try the horn button. If the horn works, you have removed the right one. If it doesn't, then it's the other.
To uncontrollable horn
