Cat removal ?
Old Jan 6, 2007 | 03:30 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Cat removal ?
Can you remove the cats without dropping whole exhaust?
Old Jan 6, 2007 | 04:26 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Yes you can, but it's ALOT easier to remove the rear exhaust section first. A couple of the hanger bolts on the cats can be a real pain getting off, assuming a LT-1. If it's a convertible you have to drop the X-brace first.
Old Jan 6, 2007 | 04:30 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
thanks
Old Jan 6, 2007 | 04:40 PM
STL94LT1's Avatar
STL94LT1
If you aren't reinstalling the factory cats. I would use a cut-off wheel/sawzall to remove the drivers side cat bracket.
Old Jan 6, 2007 | 04:55 PM
bogus's Avatar
bogus
I would cut off that bracket either way.
I removed them from the engine I put in bastet44's car.
To Cat removal ?
