Spring Protedtors Missing...........Serious?
Old Jan 6, 2007 | 06:09 PM
wooppin95's Avatar
wooppin95
Default Spring Protedtors Missing...........Serious?
Just started into the front suspension rebuild (Ball Joints and Bushings)on my 1995 coupe. I went to remove the spring protectors and.........they're not there! I don't know maintenance history for first 100K miles on this car, but it doesn't look like the front control arms have ever been off (spring also appears OEM). I know it's had at least one brake job. Either that or Bowling Green put the front caliper retaining pins in backwards from the pictures in the FSM. While I don't blindly follow The General on everything I'm thinking there was a reason they were on the car in the first place. Unless someone can suggest otherwise, I'm thinking I need to get a couple of these and install them during reassembly.
Old Jan 6, 2007 | 06:16 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you talking about the rubber pad between control arm and spring, if so, some people remove them to lower the car.
I agree, get some new ones.
Old Jan 6, 2007 | 06:36 PM
wooppin95's Avatar
wooppin95
No 86, I'm talking about the metal piece that should be bolted to the bottom of the lower control arm, outboard of the spring retainer. I can see the pads you're talking about (I think). They are between the end of the spring and the lower control arm. They are there and the rubber looks well weathered so that's one reason I think the spring is the OEM setup. I just noticed I spelled protector wrong, duh. Oh well, all I can say is the heavy lifting is done for the day and it's Miller time
Old Jan 6, 2007 | 08:04 PM
AGENT 86's Avatar
AGENT 86
Ah, must be the formed aluminum shield on the under side.
Old Jan 6, 2007 | 11:26 PM
TorchRedRob's Avatar
TorchRedRob
my 95 doesn't have 'em. I don't know if they came with the car originally, but they weren't there when I bought it a few years ago.
Old Jan 6, 2007 | 11:57 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My parts book says the spring protector was only used from 84-94.
I like em, they hold rocks and road grime and help with weight distribution.
Old Jan 7, 2007 | 08:35 AM
AGENT 86's Avatar
AGENT 86
That explains why wooppin95 doesn't have them
Old Jan 7, 2007 | 04:30 PM
CentralCoaster
Without your insight, we'd all be lost, double-oh-zero.
Old Jan 7, 2007 | 04:38 PM
AGENT 86's Avatar
AGENT 86
Without a doubt
Old Jan 7, 2007 | 05:15 PM
wooppin95's Avatar
wooppin95
Another days work done. Upper left side control arm and spindle off.
- pop tie rod end stud with puller
- support lower arm with floor jack (perpendicular to car so it will roll in as spring unloads)
- lower shock bolts out, remove sway bar end link, unplug ABS lead
- remove lower ball joint nut
- unload spring half way, remove shock, pop lower ball joint stud with puller
- remove upper control arm / spindle assy (ID and bag the shims)
- lower floor jack to unload spring
Later this week the lower arm comes off, too late in the day to get on the creeper. I'm endorsing two great tips from CF. Use a puller not a pickle fork and jack perpendicular to car to unload spring.
Thanks CF
To Spring Protedtors Missing...........Serious?
