prom programing
Old Jan 7, 2007 | 01:00 PM
junior101's Avatar
junior101
1st Gear
Default prom programing
What is the best way to set our own parameters on a prom?What are the better ways to do this and electronics needed.86 vet 350 turbocharged.
Old Jan 7, 2007 | 03:25 PM
Trog's Avatar
Trog
Start w/ the FAQ thread at the TOP of this section. There are also links in there for the hardware/software needed to make mods to a stock prom (at least the stock contents).
I use Moates software/hardware although my first ODB1 cable was from someone else on the net.
There is a TON of info here on this forum but also F-body & sites dedicated to bin modifications. I'm far from an expert but have learned a lot in the last couple years & now make my own chips for my Procharged '90.
Old Jan 8, 2007 | 12:56 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Read the stickies here http://www.thirdgen.org/techboard/diy-prom/ over and over and over again. Your head might spin a bit, but after a while, it makes sense.
I use Craig Moates' AutoProm and TunerPro RT, along with an LM1 A/F meter.
To prom programing
