Fuel Pressure Problem
Old Jan 6, 2007 | 08:20 PM
mk842766's Avatar
mk842766
Default Fuel Pressure Problem
I've suddenly lost pressure on my fuel rail...I've changed the filter, and checked the pump flow, and all seems good. Plenty of pressure from the pump, plenty of pressure to the filter, and plenty of pressure at the inlet of the rail, but I get no pressure in the rail...bad regulator???, checked the vacuum hose at the regulator, and no fuel there...any ideas??
Cheers,
Michael
Old Jan 6, 2007 | 08:49 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default fuel
if the regulator diaphragm has a tear in it, the fuel will be bypassing 100%. try taking the return line loose, add a length of hose, and pointing it in a bucket. if it's the regulator, the full fuel volume from the pump will be evident.
then try plugging the line, and checking your fuel pressure again. if it's up, it is the regulator.
oh, and go get new "o" rings for the fuel line before you separate them, a used o ring will only create a car fire at some point
Old Jan 6, 2007 | 09:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First try clamping the rubber section of the return line under the filler door.
If pressure goes to normal it's the FPR, if not the pump.
Old Jan 6, 2007 | 10:02 PM
RRT vette's Avatar
RRT vette
Check the FPR vac for signs of raw fuel.
Old Jan 7, 2007 | 09:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
What tests have you done to say there is NO pressure in the fuel rail ??
Old Jan 7, 2007 | 10:19 AM
RRT vette's Avatar
RRT vette
Old Jan 7, 2007 | 11:21 AM
mk842766's Avatar
mk842766
Checked with gauge at schrader valve....afraid valve might be stopped up, removed core, and still no pressure....
Cheers,
Michael
Old Jan 7, 2007 | 11:33 AM
AGENT 86's Avatar
AGENT 86
Cheers,
Michael
I don't understand how you can have pressure at inlet of rail and none at shrader valve.
RRT vette's Avatar
RRT vette
Sorry, missed where you already stated you checked this. I would remove the FPR and either intall new guts or replace.
AGENT 86, where's the old avatar?
Old Jan 7, 2007 | 11:38 AM
AGENT 86's Avatar
AGENT 86
Time for change
Old Jan 7, 2007 | 07:10 PM
mk842766's Avatar
mk842766
found the problem...long story short, pulled the pump, and found a piece of electrical tape in the bottom of the tank...it was getting sucked up against the sock, causing the sock to collapse, cutting the flow to almost nothing...It would pump when I opened the lines, but once it came against any pressure, the sock would get sucked shut.....don't ask me where the electrical tape came from, I've had the car for 6 years, and have never been in the tank before....
Cheers,
Michael
Old Jan 7, 2007 | 10:35 PM
RRT vette's Avatar
RRT vette
Hmmmm, wonder what else might be in there? That is a unusual problem. Would have never guessed it.
Old Jan 8, 2007 | 09:11 AM
AGENT 86's Avatar
AGENT 86
Cheers,
Michael
I sure hope you replaced the sock. A piece of tape shouldn't cause the sock to collapse unless the pores of sock are really plugged up.
Old Jan 8, 2007 | 09:55 AM
Sam Lam's Avatar
Sam Lam
Michael: Good work and I would not have guessed that root cause of your problem in a million years. One just does not consider having something like this in the gas tank
Old Jan 8, 2007 | 01:48 PM
mk842766's Avatar
mk842766
Yep...replaced it.....better safe than sorry for $5 USD....surprised I didn't hear more noise from the pump....
To Fuel Pressure Problem
