late C4 headlight motors run 5 seconds
Old Jan 7, 2007 | 08:25 PM
red86vet's Avatar
red86vet
Acct suspended by request 6 November 2012
Default late C4 headlight motors run 5 seconds
'92 Corvette - when the headlights are turned on or off, the headlight motors continue to run for about 5 seconds AFTER they are all the way
open or all the way closed. Also, when the parking lights are turned on then off, both motors will run for about 5 seconds (doors do not move).
I suspect the headlight control module but I would like to get confirmation before I spend the $$$ to replace it.
Thanks, Bob
The plastic bushings in the driven gear was the problem. I have put together a set of instructions to replace the bushings in a 1992 Corvette. The directions are from hood up to hood down. The file, including pictures, is 1.3meg. Request the file from redvette100@hotmail.com
Last edited by red86vet; Jan 16, 2007 at 04:04 PM. Reason: save time from having to look at all the postings.
Old Jan 7, 2007 | 08:39 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
You need to replace the bushings in the gear assembly. Mine were completely gone and had the same symptoms. $15 fix. No need to get the bronze gears mine were fine. Check out midamerica.
Old Jan 8, 2007 | 01:25 AM
BAM92's Avatar
BAM92
I agree, it is the 3 little bushings that can be bought from any corvette catalog. Easy fix.
Old Jan 12, 2007 | 02:21 PM
red86vet's Avatar
red86vet
Thanks for the replies. I have the bushings and they are being installed. I have had some problems with the instructions and as a result I had to remove the armature from the aluminum case as one of the armature cover screws snapped off and I had to have it drilled and retapped. Getting the armature cover mated to the aluminum housing looks to be a real chore because of the brush springs.
Old Jan 12, 2007 | 03:22 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yup, as others have said, it's your Delrin bushings. They turn to dooty typically within 8 to 10 years of normal operation.
Old Jan 15, 2007 | 05:11 PM
red86vet's Avatar
red86vet
Once I saw what was needed, compress the springs and retain the brushes in the slot, it took me about 4 minutes and the cover was back on.
Old Jan 16, 2007 | 04:37 PM
red86vet's Avatar
red86vet
I used ECKLER"S bushings/bearings - 29304. Package of 3 needed per headlight.
Old Jan 17, 2007 | 08:13 AM
onedef92's Avatar
onedef92
In most cases, you don't need to remove the main gear shaft anyway. Just the large plastic gear that drives it. I was able to tap the gear out with a small hammer, insert the new bushings, re-install the main gear, then screw the motor housing cover back on.
To late C4 headlight motors run 5 seconds
