How much does HP cost?
Old Jan 8, 2007 | 03:06 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by JD'S WHITE 93
The cap picked up 12 horsepower at the rear wheels which is pretty good from a rocker swap.
It would be.
But, if the shortys (the magazine didn't tell us what kind of headers they were!! ) were a wash, then just rockers made for a 8hp LOSS.
We can interpret the result to mean that rockers alone will cost hp, bigger injectors alone will neither gain nor lose (makes sense, that), but both together can net 12hp.
rockers: $300
injectors: $250
Cost to Benefit Ratio (CBR): $45.83 per hp.
That's not too bad.
By the way, if my memory serves me correctly, most of the heads/cam packages I've looked at are in the range of $4000-$5000 and claim a 40-50hp increase for a CBR of around $100/hp. Ouch!
Supercharging and nitrous have fairly low CBRs, but nitrous is hard to figure since the ongoing costs of refilling the bottle can take the CBR figures higher for N2O if you squeeze a lot.
Larry
code5coupe
Old Jan 8, 2007 | 03:58 PM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by SurfnSun
Thats probably nitrous, actually.
My setup so far cost me $13.6 / 1 hp. That's with extras and installation not counting cost of refills.
Edit: Was a tune done after the upgrades? Just curious.
Old Jan 8, 2007 | 04:09 PM
VenkmanP's Avatar
VenkmanP
If one is stupid about choosing mods (for instance putting 30# injectors on a car that just has bolt ons), then, certainly, the $/HP will be high.
Intelligent choice of mods can yield $/HP much lower than $50. I'd be hard pressed to spend $50/HP unless I was paying for labor or making really dumb choices.
For moderate power goals N/A on an LT1 you're looking at $25-30/FWHP if you spend wisely.
The vast majority of the H/C packages purchased for LT1s are in the $1000-2000 range.
An LE2 package plus supporting mods on an F-body will run around $3000 and provides about 400 RWHP. That's about $22/HP. Might be a little more expensive for a vette since headers are more expensive. Call it $3500 and you're still at $26/HP.
Old Jan 8, 2007 | 04:22 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
The thing that the article doesn't show you which is the most important part is the dyno chart. If a rocker and spring swap only netted an addtional 5 more peak horsepower yet the car was making an additional 15 horsepower from 2500-4500 then it's a great swap.
I've seen dyno pulls on rocker and spring swaps before and the last one I remember the peak rwhp only increased a couple yet the LT1 was making an additonal 15 horses almost across the chart and an addtional
17 ft lbs. of torque.
Old Jan 8, 2007 | 04:29 PM
gator79's Avatar
gator79
Originally Posted by jfb
Supercharging provides the highest HP/$ !
nope, nitrous does
Old Jan 8, 2007 | 04:31 PM
gator79's Avatar
gator79
you can make improvements just by changing the rockers? what do 1.6 rockers do? do they give more lift to the stock cam?
Old Jan 8, 2007 | 05:03 PM
JD'S WHITE 93
They have a higher ratio so yes more lift out of the factory cam and since they are a roller rocker they reduce friction.
Old Jan 8, 2007 | 05:21 PM
Fastmax32168's Avatar
Fastmax32168
I am with Vis on this one. I cant imagine spending what some people around here seem to be able to blow on HP. Smart shopping seems to have been replaced by Stupidity or the desire to be able to brag about how much they spent for this or that.
I picked up about 60 HP on my LT1 with about $1500. And if I hadnt wanted such a mild camshaft (213/219) those numbers could have been considerably higher. Its all about intelligent shopping and doing the work yourself.
Going fast doesnt have to cost a fortune. Some folks just seem determined to make it so.
Roy
Old Jan 8, 2007 | 05:25 PM
JD'S WHITE 93
Horspower isn't cheap but one thing to keep in mind especailly with an LT1 Corvette is the factory 2.59 rear gear that came in thousands of them is the problem. Take the same car they did the rocker swap on and instead of doing that go with a 3.73 rear and you'll still have the same c.h.p. you did before you started but the car will be alot quicker.
Old Jan 8, 2007 | 06:02 PM
rocco16's Avatar
rocco16
I have to ask the obvious: is that 60hp measured on a dyno or is it what the parts manufacturers said they (whatever "they" were) would give you?
Big difference....which is the whole point of this thread.
True enough, but the subject of this thread isn't quicker quarter-mile times, but increased engine output.
Larry
code5coupe
Old Jan 8, 2007 | 06:10 PM
1stvette94's Avatar
1stvette94
The bottom line with any mod is timeslips, they don't ever lie!
Old Jan 8, 2007 | 06:20 PM
Fastmax32168
Larry
code5coupe
Larry,
I cant believe you would even ask me that.
255 to 316 on a Dynojet.
Roy
Old Jan 9, 2007 | 09:33 AM
  #33
rocco16's Avatar
rocco16
Where in the world can you find two GOOD heads and a DECENT cam for $1000??????????!!!!!!!!!!!!!! (unless you are talking about bare iron heads and just a cam w/ no springs, etc.)
Roy
You deserve a prize for that! (..but, I guess, 316hp is a nice award!)
Larry
code5coupe
Old Jan 9, 2007 | 11:00 AM
  #34
rickneworleansla
Larry
code5coupe
Maybe he was talking about having the stock heads ported.? Not $1000 but still cheap at $1100 for the least expensive.
http://www.eportworks.com/LT1LE1.htm
http://www.eportworks.com/LT1LE2.htm
Old Jan 9, 2007 | 11:43 AM
  #35
GeosFun's Avatar
GeosFun
Yeah, I think the "stupid" and "dumb choices" comments are a bit extreme. Forrest Gump said it best.
Old Jan 9, 2007 | 12:10 PM
  #36
VenkmanP's Avatar
VenkmanP
And the number one reason for spending way too much $/HP is....
Being ignorant of the available options, and not paying attention to the results (good or bad, expensive or cheap) gained by the thousands of people who have gone before you.
Old Jan 9, 2007 | 12:25 PM
  #37
65Z01's Avatar
65Z01
Cruise-In II Veteran
Unfortunately there is a learning curve when adding HP to a C4. I had the opportunity to gain some experience on my TPI IROC-Z before tackling the '88 Vette L98.
Before the A4 mods I had about $3,800 to go from 240chp to 297chp or about $35/HP (at the crank). These consisted of a few "freebie" mods along with exhaust work, RRs, underdrive pullies, AFPR, low temp T-stat and the like. The intake work was mostly hand porting so cost was neglibible.
Though the A4 work dropped my 1/4 mile time it did not add any peak hp.
Doing a cam would run around $700 and net 30chp gain for $23/HP, porting the stock #113 heads with new valves might run $700 and net 30chp gain for $23/HP, adding FL headers with true duals would run say $1,500 and yield 15-20chp gain for $100/HP.
So for another $3k I could be running close to 380 HP at the crank for a net cost of $49/HP, not far from a figure I saw earlier in this thread.
It's really all about knowing your goal, your engine (and drive train) and how to achieve the ends most efficiently.
One advangage the L98 guys have is that these engines respond so very well to mods though the intake does limit max HP.
To How much does HP cost?
Old Jan 9, 2007 | 01:04 PM
  #38
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Is there a good CNC porting service for L98 113 heads.
Old Jan 9, 2007 | 02:02 PM
  #39
rocco16's Avatar
rocco16
$66.66/HP
Larry
code5coupe
Old Jan 9, 2007 | 03:11 PM
  #40
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
$66.66/HP
Larry
code5coupe
