Door panel ?
Old Jan 8, 2007 | 03:05 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Door panel ?
Is there any tricks to taking off the door panels on a 93?
Also, my door lock sticks on the pass. side, is this a common problem and how can I fix it?
Old Jan 8, 2007 | 08:28 PM
96polovette's Avatar
96polovette
I just went through it on my 96. I found it pretty straightforward. Disconnect the negative battery terminal as you will be disconnecting electrical wires in the door. There is a screw in the back edge of the door about at elbow level that needs to come out. There are 3 screws in the door handle area. Also remove the 2 screws from the cup in front of the armrest. The cup just pulls out. Pry down on the door light above the handle and pull the light out about an inch. Gently pry out the manual door lock from the door handle area with a screwdriver. Gently pull the door panel off the door frame releasing the plastic pegs at the bottom one by one. Next disconnect the wiring for the hatch release, power mirrors, and power windows behind the panel and it should come free. If it isn't coming loose you have missed a screw somewhere or forgot to remove something. The key is to take your time and be gentle with all the parts, don't try to force anything, if you did it right everything comes off easily.
As for the manual door lock, check how it is aligned, there is a place inside the plastic lock handle to accept the metal bracket that goes into the inner door lock mechanism. Also check that the metal bracket lines up properly without the plastic door lock lever on it. Check to make sure the 3 screws around the handle are tight. Everything should have a clean path with little resistance. It could be your power door lock is wearing out on the passenger side. Replacing that is a trickier job as you have to go deeper into the door to replace it.
I hope this helps.
Old Jan 8, 2007 | 08:41 PM
94z07fx3's Avatar
94z07fx3
Is there anything better than white lithium grease for the moving parts in the door? For the lock itself, I've used a spray lube from slick 50 in a red can. It's thinner than the WLG.
Old Jan 9, 2007 | 12:36 AM
93*Corvette's Avatar
93*Corvette
Just as 96polovette said. To make one thing clear, there is one screw located behind the window up/down switch. Pull the switch out and you will see the screw. This one took me forever to find....
Here is the location on my 93... The upper handle was loose, then broke completely. This is why I removed my door panel. To fix the handle, it just require a screw. You may want to tighten yours since it constantly being pulled on...
Old Jan 9, 2007 | 01:38 AM
Travis93's Avatar
Travis93
[QUOTE=93*Corvette;1558436506]Just as 96polovette said. To make one thing clear, there is one screw located behind the window up/down switch. Pull the switch out and you will see the screw. This one took me forever to find....QUOTE]
This is the one that got me for quite a while.
As far as the locks both of mine were sluggish. The metal rod behind the plastic lever was rubbing and causing a bit of a bind. After straitening that out and coating all the moving parts in the door with silicone spray both locks snap quickly just like I would expect them to if they were new.
Old Jan 9, 2007 | 07:24 AM
runner140*'s Avatar
runner140*
I hope this helps.
Nice post, well done.
Old Jan 13, 2007 | 04:47 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
one last question, what is the order of sequence for the connectors on the window switch.
From the top I know it is brown then black, what color comes next, the FSM does not say and I am in a bind.
Thanks!!
Old Jan 13, 2007 | 09:51 PM
rickslt4's Avatar
rickslt4
my 95 and 96 don't have screws on the aft end. i can see where they might go as there is a molded bracket on the frame but no screw. anybody have a pixie?
Old Jan 14, 2007 | 12:59 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Can someone who has a 93 tell me the which color wire goes to which plug, starting from top to bottom.
Old Jan 15, 2007 | 10:59 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
ttt
Old Feb 17, 2007 | 10:29 AM
93cruiser's Avatar
93cruiser
Default Manual door lock removal
How do gently pry the manual door lock slide off?
How is secured?
Thanks for any help
Old Feb 17, 2007 | 01:05 PM
93*Corvette
How is secured?
Thanks for any help
If you mean the slide lock thingy, it's just pushed in. Pry it off..
To Door panel ?
