Headlamp Wiggles
Old Oct 1, 2001 | 02:08 PM
Camvette's Avatar
Camvette
Default Headlamp Wiggles
As I'm driving, the headlight vibrates. This makes the light dance around on the road. The other light is tight and doesn't do this. Also if you try to wiggle the right side light, you can. The left side won't move. Is there a adjustment for this or what do I need to replace? :confused:
Old Oct 1, 2001 | 07:18 PM
Raysur's Avatar
Raysur
Default Re: Headlamp Wiggles (Camvette)
There should be adjustable bump pads on the inside of your hood. Check them out and make sure they make contact with the headlight.
Old Oct 1, 2001 | 09:59 PM
Z06_BluByU's Avatar
Z06_BluByU
you might need new bushings in your headligh motors. if so contact Mr Cj and he'll get you some new ones for 12 bucks.. easy to replace!
To Headlamp Wiggles
