Changing Fluids - brands...
Why is the higher viscosity recommoneded?
Is the increased viscosity (10W60) to provide more protection and help with that common failed axle seal??
GM Clutch fluid P/N 12345347 (Dot3 grade with friction modifiers). While the Valvoline Synpower is a good fluid it does not contain the additives used by GM for the clutch system.
Be well,
SJW
1. You don't need two bottles of LS additive with the Syntec diff oil.
2. Thoroughly flush the brake and clutch system because you don't know what was in there.
Be well,
SJW
1) The NEW coolants are green, again. Prestone makes a version that is compatible with both old green and newer orange. Nothing to fret there.
2) I have been using Valvoline Synpower for the last 4 years in both my clutch and brakes and have had ZERO issues with either... infact, my clutch hydraulics are almost 5 years old. They leak, yes, but not to the point where they quit.
3) All this talk about oils... as far as motor oil is concerned, if you get a major brand (Mobil, Castrol, Valvoline, Amsoil, Royal Purple, et.al.) synthetic, and change it every 4~5k miles, you will never experience an oil failure. I know some of the modern synthetics will go farther, but I have issue with that. I need some more empirical data to go with before I risk that. Also use a good filter, such as the AC Gold, the Mobil 1 or K&N. Stay clear of the $4.00 cheapo's.
4) As for the rear end. I prefer the mixture of conventional gear oil with the additive. For some reason, it just makes more sense to me. Essentially, with the LSD, it's the way Dana engineered it (the ZF accepts the Castrol, both via ZF Doc AND ZF themselves), if Dana has an alternative product, I would be willing to listen. But experiementing with a $1000.00 diff seems silly to me. Change the fluid every 30k.
C4 Guru - Changing Differential Fluid.
5) The BMW oil may be a higher viscosoty, but it hasn't hurt my ZF in 100k miles... it has 160k and shifts just fine.
C4 Guru - Changing ZF6 Fluid.
I understand that half of the brand types are personal perference and work fine.
So with that, I've concluded the following for my vehicle:
(selected in Blue)
OIL
-Mobil 1 Synth (most common)
-AMSOIL Series
-[Other synthetics]
NOTE: Change every 6mo/3k miles (I drive low miles).
COOLANT
-DexCool with distilled water 50/50 (for 1996 ONLY!!!) <-until I find research otehrwise...
-Prestone Extended Life (says its compabile with all colors)
NOTE: Change every 5yr/30k miles.
COOLANT ADDITIVE
-Redline Wetter Water or other (Not required but it wont hurt)
DIFFERENTIAL FLUID
-Castrol Syntec Gear oil (and add GM addtivie)
-Mobil 1 (and add GM addtivie)
-AMSOIL Synthetic (already has additive)
-Royal Purple (and add GM addtivie)
-Redline Synthetic (and add GM addtivie)
-[Other synthetics]
NOTE: Change every 30k miles.
MANUAL TRANS FLUID
-AMSOIL Synthetic Synchormesh MTF (5W-30)
-BMW M5 Castrol 10W-60 Oil <-zfdoc says only use this... (not Mobil1)
NOTE: zfdoc.com says change every 15k per tests. GM manual says Never. I don't believe either (somewhere between).
BRAKE FLUID
-Valvoline Synpower
-Delco Sumpreme 11 (PN 1052535)
-[Other synthetics]
NOTE: Found artile says change every year. Seems excessive.
NOTE: Change every 50k miles.
CLUTCH FLUID
-Valvoline Synpower
-GM Clutch Fluid w/ modifiers (PN 12345347) <-zfdoc says only use this...
-[Other synthetics]
POWER STEERING FLUID
-Valvoline Synpower
-Redline Synthetic
-[Other synthetics]
Thanks all!! U guys are awesome!!
I have Dex-Cool in my LT4, and have had no problems. The Dex-Cool vs. Green coolant seems to stir up more debate than any other topic. I would stick with what it came from the factory with.
plus, Dex does seem to be more leak prone for some reason.
if you keep the Dexcool, just be sure to keep a close eye on its condition...
