Changing Fluids - brands...
Old Jan 10, 2007 | 02:33 PM
nogoodsam's Avatar
nogoodsam
Default Changing Fluids - brands...
All,
I'd like to change all the fluids of my newly purchased 1996 LT4 (2 months ago). It only has 21k miles. The previous owner did it 5 years ago but I don't know the brands. So I'm considering of just changing all the fluids anyways since fluids are #1 way to maintain a good car!
(I've searched the forum and came up with the following)
FLUIDS:
OIL - Mobil 1 Synthetic (w/ Mobil 1 filter)
COOLANT - Havoline Dex-Cool with Distilled Water (50/50)
COOLANT - Supplement Sealer (any brand?)
DIFFERENTIAL - Castrol Syntec Gear Oil (75W-90)
DIFFERENTIAL - GM Limited Slip Diff. Additive (2 bottles)
MANUAL TRANS - BMW Model Castrol TWS 10W-60
BRAKE - Valvoline Synpower
CLUTCH - Valvoline Synpower
POWER STEERING - Redline Synthetic
Are these fluids brands going to provide good performance?? Any opinions?
(I’m willing to pay extra but want to be smart about it too - value...)
Thanks....
Old Jan 10, 2007 | 03:31 PM
STL94LT1's Avatar
STL94LT1
They all look good except the coolant supplement sealer, which I wouldn't use.
Old Jan 10, 2007 | 03:32 PM
Corvette Chris's Avatar
Corvette Chris
I'd run regular green coolant instead of the Dex-Cool, but thats just me.
Old Jan 10, 2007 | 03:40 PM
nogoodsam's Avatar
nogoodsam
Why? Cooling properies better with green?
Old Jan 10, 2007 | 04:26 PM
biteme86's Avatar
biteme86
Fluids seem like top brands. I thought you wernt suppose too mix different colored coolants? Wouldnt you just stick with green all the way around and just add distilled water.
Old Jan 10, 2007 | 04:42 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
1996 Corvette came from the factory with Dex-Cool coolant. Do not ever mix the two! If you insist on changing over the the geen stuff, you better make sure you have a complete flush and no trace of Dex-Cool left. Otherwise you'll create "sludge".
I have Dex-Cool in my LT4, and have had no problems. The Dex-Cool vs. Green coolant seems to stir up more debate than any other topic. I would stick with what it came from the factory with.
Old Jan 10, 2007 | 05:07 PM
STL94LT1's Avatar
STL94LT1
Old Jan 10, 2007 | 05:44 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
1996 Corvette came from the factory with Dex-Cool coolant. .... I would stick with what it came from the factory with.
So would I.
The Dex-Cool is designed to be compatable with..and to provide protection for...the various alloys, plastics, and gaskets in the LT1's cooling system. I would NOT go to an older formulation of coolant.
Everything else on the list looks fine....they may not all be the ONLY good fluids available, but each of them will be as good as anything else you could put in there.
Larry
code5coupe
Old Jan 10, 2007 | 05:56 PM
1stvette94's Avatar
1stvette94
Besides the dealer, where can you get the BMW fluid for the trans?
Old Jan 10, 2007 | 06:08 PM
rws.1's Avatar
rws.1
I've never been a big Castrol fan..
For the rear diff Gear oil I would go with Mobil 1 75W90
or Royal Purple (internationally known for their gear oils, both passenger car and industrial)
+ the GM addtive as you indicate...
Some go with the Amsoil gear oil and skip the additive...since Amsoil claims it is already in their gear oil...
Old Jan 10, 2007 | 08:38 PM
STL94LT1's Avatar
STL94LT1
I'm pretty sure it can only be purchased at a BMW dealership.
Old Jan 10, 2007 | 09:00 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
If your going to change the clutch fluid, replace it with the GM hydraulic clutch fluid, check out zfdoc.com for the correct part number, it works the best.
Good Luck,
Randy
Old Jan 10, 2007 | 09:04 PM
Bob CTS's Avatar
Bob CTS
I swear by Valvoline syn-power for the Brake and clutch fluids, it was I use in all my vehicles.
Bob
Old Jan 10, 2007 | 10:07 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL gear lubes do have the friction modifier pre-mixed in. I've been using their 75w90 in my Z06 on the track for years without ever needing to add additional modifier and haven't had any diff issues (other than a failed left axle seal which is common on Z06s).
For the original poster, if you are interested in AMSOIL fluids, these are the ones applicable to your 96:
Engine oil:
Best - AMSOIL Series 2000 0w30
Very good alternatives:
AMSOIL SAE Synthetic 10w30
AMSOIL SAE Synthetic 5w30
Manual Tranny: AMSOIL Synthetic Synchromesh Transmission Fluid (MTF)
Diff: AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
For the DIYer, this comes in handy: AMSOIL Hand Pump
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 11, 2007 | 07:36 AM
runner140*'s Avatar
runner140*
Old Jan 11, 2007 | 08:05 AM
tomtom72's Avatar
tomtom72
Active Streak: 90 Days
St. Jude Donor '08 thru '26
Default Two cents more....
.....about the trans fluid. I think you should go to zfdoc.com & read up on the trans oil issue before you make any choices. The zf6 uses an uncommon GL rated fluid. The GL ratings are not interchangable. If a trans calls for GL4 you can't put GL5 in it. If I remember from Bill's site the zf6 in the C4 uses GL4 rated fluid, I think??? BMW/Castrol oil is M5 motor oil but it has the correct GL rating for our zf6's. It's only sold at BMW parts counters, no parts stores carry it.
One thing about the trans fluid change, make sure you get the fill plug out, 17mm hex socket, before doing anything else. They are hard to get out the first time around....sometimes.
Tom
Old Jan 11, 2007 | 08:36 AM
RobWilson's Avatar
RobWilson
I changed all my fluids when I bought my '96 (5 months ago). I used Redline synthetic gear oil, GM diff additive , Motul brake fluid, and the GM supplemental sealer in Dexcool coolant.
To Changing Fluids - brands...
Old Jan 11, 2007 | 12:19 PM
nogoodsam's Avatar
nogoodsam
Ok.....from zfdoc.com about transmission fluid.
"TRANSMISSION OIL (status) - Vascular flow of oil through the porous Phosphorus-bronze (Pb) material of each synchronizer is essential for effective British Thermal Unit (BTU) heat exchange occurrence. Frequent transmission oil changes will ensure lower Pb particle levels suspended in the oil. The ZF S6-40 6-speed transmission is lubricated by engine type oil. Manufacturer recommendations specify the use of GM P/N 1052931 (5w-30) or BMW P/N 07510009420 (10w-60) oil.
Approximate oil capacity of the ZF S6-40 is 2.2 quarts.
FYI - the BMW 10w-60 oil is fully-synthetic and is used in the BMW M5 engine. "
TRANS OIL - BMW M5 10W-60 motor oil is definitly the way to go!
COOLANT - For my 1996 I will stick with DexCool and NO SEALER!!
CLUTCH FLUID - Valvoline Synpower OR GM Clutch fluid P/N 12345347 (Dot3 grade with friction modifiers)
Thanks for all the inputs!!!!
nogoodsam's Avatar
nogoodsam
Why no sealer?? Any direct experience?
Old Jan 11, 2007 | 12:29 PM
C66 Racing's Avatar
C66 Racing
Originally Posted by nogoodsam
... Manufacturer recommendations specify the use of GM P/N 1052931 (5w-30) or BMW P/N 07510009420 (10w-60) oil.
There are some downsides to the BMW 10w60 though, including cost and double the viscosity recommended. There are fluids out there, such as the AMSOIL MTF that I linked above that are specifically designed for your C4 tranny and labeled to meet the specifications for GM Part 1052931. They are not gear oils. These aftermarket synthetics have the proper additives and viscosity (5w30). While I'm sure the BMW 10w60 will work as so many recommend and use it, you will be losing HP and fuel economy due to increased drivetrain friction.
