60 + injectors does nay one have some?
Why are you looking for the bigger low impedence injectors now? You may wish to rethink 60/70/80 lb/hr injectors.
Hey maybe you like a challenge, and can get someone to pass a really rich car through emissions. Tuning is key.
Aaron
,,thaxs for the email info,,i have seen and readed only about larger injectors are the best,,,so what is 42 lbs...or 55..or 75...what ....i produce aboout 425 at the rear wheels now,,,,but planning to put the paxton s.c...sn93,,,,with only 8 lbs of boost,,i like to have 10 to 12 lbs,,,,so does mean i need bigger or smaller injectors,,,as they something i'm missing heres? please tell me know before i screw-up my vette
i will be at the houston vette this feb...hope the meet some good vette friends there...SO WHAT EVER U GUYS CAN TELL ME NOW WILL HELP OUT ALOT!!!!...
i will be at the houston vette this feb...hope the meet some good vette friends there...SO WHAT EVER U GUYS CAN TELL ME NOW WILL HELP OUT ALOT!!!!...If you add the spray on top (which clearly it is a wet kit), you will not need additional injector flow rate for that adder but I can bet that you may need some new engine pieces.
I think that I would be looking at some 42FMS injectors (or the 30s may be fine for now). Additionally, these FMS injectors are high impedence, so they will work fine with the factory ECM.
I will be at the Corvette & Chevy Show in mid Feb as well. There will be lots of vettes at the George R Brown Convention Center.
Aaron
For example..
Your car can not run those big *** 72s,83s,96s low Z injector you are talking about. This big *** injector are for people with extensive engine modifications and making 700-1000rwhp range.
For your little 350ci with long runner intake and the that litttle baby supercharger you are talking about. the 42s injector is more than enough that your little paxton supercharger throwing at it. The 42s injector is capable to handle 500rwhp in forced induction. I doublt that your paxtion supercharger can ever deliever that 500rwhp range. If I have to guess.. At the most hp you will ever get is about 375rwhp..
Good luck man.
Thanks,
Chris
We sell the Siemens 60lb injectors, which are very easy to tune with. Bob
